Thread: Weber setting for a 2.2S Motor
    Sorry but this is a multi-part question.
    What is thinking around jetting a 2.2S motor with 40mm Webers ?
    This is a "stock" spec 2.2 S motor ( minus MFI w/ headers ) . Typical altitude will be 1000ft. Gas will be pump, east coast.
    are there other complimentary components the forum members have found to work well on a 2.2 motor with carbs ? example dosing gas ? ( mix race gas ? mix MMT in etc) spark plugs etc etc
    George
    1971 911E
    1964 26R (narrow arch)
    1965 26 GTS ( sold to fund 911E restoration)
    1965 912 ( sold to pay for 26R head)
    George,
    You should be OK on 93 octane pump gas; I would NOT add any octane boosters to the fuel due to unintended consequences.
    For jetting, I would start with:
    34mm venturies
    140-145 main jets
    180 air correctors
    F3 emulsion tubes
    50-55 idles
    Make sure you have 3.5 psi of regulated fuel pressure and the float levels are perfect.
    Steve Weiner
    Rennsport Systems
    Portland Oregon
    503.244.0990
    Thanks Steve -
    I assumed I need a bit more than the OEM 2.0 liter S set up. Is a 34mm choke the last step before 46's ? ( the ROT for DCOE's is/was 1.25xChoke tells you when to step up in barrel size)
    Do you have a plug wire combo ( The Twinks like the NGK/Magnacore) ?
    George
    1971 911E
    Quote Originally Posted by Steve@Rennsport View Post
    George,
    34mm venturies
    140-145 main jets
    180 air correctors
    F3 emulsion tubes
    50-55 idles
    Steve's numbers look to be right on. I have a similar motor (2.4S with 2.2 P&C's) and Bruce at Klubsport set them up w/ 34mm venturies, F3 Emulsion tubes, 185 correctors, 150 mains, and 50 idles.
  1. Setting up Konis
    By Fishcop in forum Technical Info
    Last Post: 07-17-2015, 12:01 PM
  2. Need help setting value of pair of near NOS Weber 46's
    By tomkirkcis in forum General Info
    Last Post: 09-19-2013, 05:35 AM
  3. Replies: 8
    Last Post: 09-01-2012, 05:47 PM
  4. Fleebay Engine: 1968 Porsche 911S Engine 901/02 Weber IDS 40 Carbs 911 S Motor
    By Doc72 in forum For Sale/Wanted: Other Porsche Cars and Parts
    Last Post: 08-31-2012, 07:09 AM
  5. torque setting please
    Last Post: 07-24-2011, 09:45 PM
