Thread: Bursch muffler installation questions - urgent
    I bought a used 2in 1out bursch muffler had it blasted and recoated then installed it tonight.
    Does it have/need a mounting bracket?
    I have a 3.2 with SSI's and the flanges of the muffler didn't quite line up - is the muffler tweaked? I had to push about 1/8" to get the muffler to bolt up will this cause stress cracking on my SSI's?
    The outlet is actually inclined slightly upwards - very wierd. Is it likely the muffler is tweaked or is it not for a 911?
    Since this muffler is now on my car and I want to drive it in the morning feedback is great appreciated.
    Mark
    1973 911T Targa 3.2 hot rod - Sold
    1992 964 C2 - Sold
    1988 VW Single Cab Truck - For Sale
    1985 VW Double Cab Truck
    Go ahead and drive it, you won't hurt anything in the short term, but over the long haul the lack of a support system means all the weight of the muffler is hanging on the heat exchangers, unlike the original system where the muffler is properly supported on the engine mount. It's not unusual for the bolt holes to not line up perfectly. I sometimes loosen all the heat exchanger nuts, so the exchangers can shift slightly on the mounting studs when bolting up a muffler. May help to line up the holes better.
    Thanks Ed.
    Does anyone have a photo of how they mounted their's?
    Mark
    1992 964 C2 - Sold
    I am running the Bursch on my track car. It is awesome.
    I am not running a strap and it causes the support on the back of the h'xers to break. I have had to weld it up more than once.
    I am going to put a strap on the mffler this year - possibly jusy use all round strapping.
  1. 69-73 Bursch Muffler
    By letsrollbabe in forum For Sale: 911 Parts
    Last Post: 08-10-2011, 07:41 AM
  2. Bursch Headers
    By Dmill in forum For Sale: 911 Parts
    Last Post: 06-27-2008, 06:15 PM
  3. Sport Muffler vs Bursch "Muffler"
    By jhora in forum Technical Info
    Last Post: 06-06-2007, 03:19 PM
  4. Sport Muffler Recommendation Questions
    By joshkras in forum General Info
    Last Post: 02-04-2005, 04:54 PM
