Thread: installing washer pump
    Member jkolesa's Avatar
    Royersford, PA
    i removed the washer bottle on my 1971 911s targa, disconected the wires and hoses from the pump and pried it off the bottle. now i cant get the new pump on the bottle. seems like you would have to push back from the inside as you push the pump on (which you of course cant). is there a trick or is it even possible to attach a new pump to an old bottle?
    1971 Porshe 911S targa 2.7 RS Carrera motor
    1991 BMW E30 S52 conversion
    2001 Volvo V70 T5
    subscribed
    Olin - Member #1375
    1972 911T
    Original
    Options added
    I grind a little off the corners of the mount to make it easier to twist onto the bottle, then I use a VW jack handle (it's a round bar with a 30 degree bend on one end) that I insert into the bottle hole and the 30 deg. end will push against the nub the pump snaps onto.
    Royersford, PA
    thanks, as long as i know its possible ill persist.
    2001 Volvo V70 T5
  1. WTB: washer bottle with pump
    By gregbus in forum For Sale: 911 Parts
    Last Post: 10-07-2011, 06:48 AM
  2. Replies: 3
    Last Post: 06-08-2011, 08:28 AM
  3. WTB 67 washer pump bracket
    By tomkirkcis in forum For Sale: 911 Parts
    Last Post: 02-16-2009, 04:20 AM
  4. 67 washer pump location
    By tomkirkcis in forum General Info
    Last Post: 02-02-2009, 03:53 PM
  5. 67 washer pump
    Last Post: 05-30-2007, 12:59 PM
