Results 1 to 10 of 13
Thread: Gear Box FUBAR
    Jun 2003
    Bend, Oregon
    Gear Box FUBAR
    I just had my transmission rebuilt by a local shop. It was making a lot of noise and we suspected the ring and pinion, which turned out to be the culprits. They were replaced, along with bearings and synchros. I was advised that my original gears (A-F-M-S-X) were in great shape and we could go ahead and use them.
    Well, the car is quiet. And shifts smoothly. But....
    I have a very good feel for this car as I have driven it in a number of high performance events. The car feels exactly the same in first and second as it did before, but a shift to third feels like going into overdrive. There is a 50% drop in RPMs from 2nd to 3rd - and then only a 10% drop from 3rd to 4th. It's just about impossible to keep things in the power band when going from 2nd to 3rd. The transmission shop insists that they replaced the same gears that they removed, but of course that is impossible.
    I know there are some gear experts on the list. Can you tell from the information I have provided what is going on? My sense is that the original "M" 3rd gear has been replaced with something like an "O" or a "R".
    Thanks for your help.
    John Audette
    Did they flip third gear? Is that even possible?
    Restoration newbie.
    Jun 2007
    San Francisco
    You can flip 3rd but then it fits in either 4th or 5th position.
    Perhaps they flipped both 3 and 5 and then transposed them
    giving you something like A-F-P?-S-ZA.
    Does your 5th feel taller?
    andy
    67S in pieces
    EarlyS: 1358
    [SIGPIC][/SIGPIC]
    Oct 2008
    Burford, ON, Canada
    It is pretty difficult to flip a gear if you watch what you are doing. When done properly there is a progression of sizes and the angle of the gears on a shaft are all the same. A flipped gear just stands out like a sore thumb. Third can be flipped into 4th or 5th or vice versa.
    Jun 2003
    Bend, Oregon
    The ratios are about right for flipped gears. We're going to remove the gear box and open it up at my shop next week. I'll report back what we find.
    Thanks for the input.
    JohnA
    Senior Member Grady Clay's Avatar
    Sep 2004
    Unincorporated Arapahoe County, Colorado, USA
    Quote Originally Posted by jaudette3 View Post
    JohnA
    If the gears didn’t get in the correct position, I would want to confirm that the differential bearing pre-load is correct, the pinion position is correct and the backlash correct.
    Please post an image of the gear cluster as it is removed. That should be interesting (in a comical sort of way).
    Best,
    Grady
    Jun 2003
    Bend, Oregon
    Took the gear box apart this morning and here's what happened.
    3rd Gear
    "S" 4th gear, 25:26, installed in 3rd gear position: 1.040; correct "M" 3rd, 22:29, is 1.318
    4th Gear
    "X" 5th gear, 28:24, installed in 4th position, and also reversed to 24:28: .857; correct "S" 4th, 25:26, is 1.040
    5th Gear
    "M" 3rd gear, 22:29, installed in 5th position, and also reversed to 29:22: .759; correct "X" 5th, 28:24, is .857
    With the correct "F" 2nd gear of 1.889 and the incorrect "S" in the 3rd gear spot, the drop from 2nd to 3rd was 45%. I had estimated it at 50% judging by the RPM drop. The correct drop, with correct "F" and "M" gears in place is 30%.
    With the incorrect "S" gear of 1.040 in the 3rd gear spot and the incorrect "X" gear of .926 in the 4th gear spot, the drop from 3rd to 4th was 11%. I had estimated it at 10% judging by the RPM drop. The correct drop, with correct "M" and "S" gears in place is 21%.
    With the incorrect "X" gear of .926 in the 4th gear spot and the incorrect (and reversed) "M" gear of .759 in the 5th gear spot, the drop from 4th to 5th is 18%. The correct drop, with correct "S" and "X" gears in place is 17.6% (even a blind dog finds a bone once in a while I guess).
    Kind of like having a three speed: first, second and 3-4-5 overdrive. Probably good on gas mileage, but a little boring to drive.
    FUBAR was right. I can't for the life of me figure out how someone who does this for a living can screw up so badly. The shop is backing its work and will pay for the engine/trans R&R in addition to setting the gears correctly. Back on the road by mid-week.
    Cheers,
    JohnA
    Jan 2003
    UK
    Unbelievable !
    Glad you're getting it sorted John
    Andy
    Early 911S Reg #753
    R Gruppe #105
    Apr 2003
    Portland, OR
    John,
    Glad it is getting sorted out and that the shop is standing up for it's mistake.
    Harry
    Member #789
    2009 MB C300
    Oct 2008
    Burford, ON, Canada
    Um, FUBAR is a very apt description for this configuration.
    I glad it is a simple mistake to correct.
  1. WTB: B 1st gear and GA 2nd gear for 901 transmission.
    By RSwannabe in forum For Sale: 911 Parts
    Last Post: 01-20-2013, 10:25 PM
  2. 901“x” gear set
    By marankie in forum For Sale: 911 Parts
    Last Post: 01-31-2012, 05:42 AM
  3. WTB gear sets for 911/01 gear box
    By 60surfer in forum For Sale: 911 Parts
    Last Post: 05-31-2009, 09:27 AM
  4. Mkt $ For 901 S Gear
    By jhora in forum For Sale: 911 Parts
    Last Post: 04-30-2007, 04:37 AM
