Thread: High Altitude weber jetting recommendations needed
    I'm running the Bogus Basin hill climb this weekend and need some jetting help.
    The top of the run is about 6000 ft. I live in Portland (nearly at sea level) where my track thrasher runs perfect. My issue last year was increasingly poor throttle response the higher I got.
    The engine is a fresh euro SC 3.0L: stock cams, 1.5" headers, sport muff, 40mm webers, 36mm venturies, 60 idle jets, 150 mains. I haven't taken them apart to see which emulsion tubes.
    Recommendations appreciated!
    Tom F.
    '67 911S Slate Gray
    '92 964
    #736
    Simple rule of thumb is to decrease mains to 145 to 140.
    A forum regular on the Pelican site has a tracked, solex cammed 2.7 w/34's @ 5500 ft and runs 150/155 mains, 200 Air Correctors and 50 idles with F3's.
    The 200 air correctors are quite large but I suspect they help lean out the F3's at the top end. He would probably use 155 mains at sea level.
    Paul Abbott
    Early S Member #18
    Weber service specialist
    www.PerformanceOriented.com
    info@PerformanceOriented.com
    530.520.5816
    I believe the basic rule of thumb is 2% change every 1,000ft. You have roughly a 12% change, so if you ran a 150 main at sea level change to a 135 for the 6,000 altitude.
    Thanks for the help, I borrowed a set of 140s. I was able to shave 2 seconds off my time from last year.
    I actually had none of the hesitatation even with the 150s though, so I guess the problem had more to do with my worn out motor. Honestly I couldn't detect any difference in the way it ran with the smaller jets.
    Tom F.
    '67 911S Slate Gray
    '92 964
    #736
    Senior Member Neunelfer's Avatar
    Dec 2002
    Sandy, Utah
    I'll second the 50 idles living here at 4,500.
    Eric - Sandy, Utah
    71 911
    914-6/GT
    914-6/ORV
    87 944 Spec 1
    Porsche Truck
    62 Beetle
    80 VW “Caddy” Pickup
    72 R75/5 Toaster Tank
    PMB Performance
    Love Us On Facebook
  1. Correct Weber jetting for a 2.9?
    By s2guy in forum Technical Info
    Last Post: 01-21-2010, 08:48 AM
  2. Weber Jetting
    By pacarguy in forum Technical Info
    Last Post: 06-28-2008, 10:27 AM
  3. Weber jetting on a 2.2 E
    By RPMClassic in forum Technical Info
    Last Post: 05-06-2008, 11:44 AM
  4. Weber 40 IDA jetting
    By zaza in forum Technical Info
    Last Post: 03-08-2005, 09:51 AM
  5. weber IDS carbs - jetting
    By swb911s in forum Technical Info
    Last Post: 04-03-2003, 04:26 PM
