Page 3 of 3 FirstFirst 123
Results 21 to 24 of 24
Thread: paint code help please
  1. #21
    No, that makes no sense. A type of paint with high VOC's perhaps, but not individual colors. They should be able to get the color you want in the new (approved) formulations. You need to find the details of the correct paint and give it to these clueless techs.
  2. #22
    Glasurit shows Metallic Blue available in their Line 55 (solvent-based) and Line 90 (water-born base coat/VOC compliant)...
  3. #23
    Nov 2003
    Santa Monica CA
    paint
    At this point I would only go with Glasurit german paint to get the best results. And go with the 55 line. If your shop wants only to do PPG; I would find a shop that will do Glasurit. Its your car-- you have to live with it after it is done,not the body shop. I am sure a shop that shoots Glasurit has the correct color codes and that is the most important aspect of a paint job to look factory correct. But a factory looking paint will look different than one done today because the solvents used today are different than the ones used 30 years ago;which means it even more important to go with Glasurit to even get into the ball park of a correct looking tone of Gemini Blue Metalic. Good luck Regards Chris Early S#205
  4. #24
    PPG signal formula
    Quote Originally Posted by 911E&26R View Post
    It might be a customer service issue at the paint store - Yesterday I walked into a local PPG store and asked for signal orange - The guy at the counter looked the color up and asked what paint i wanted and how much ( I got a pint to test) they went to make it up and came back out and said there might be a delay because on of the tint bases asked for in the formula was no longer available - Guy at the counter got on the phone and got the formula for Signal orange with the new tint - I walked out with the can below 10mins later -
    George
    PS - my store say's they found the color in the Nexa database , and also found a lacquer formulation -
    Do you have the formula by any chance please? About to paint mi '71 911 Signal Orange. Look a bit brown to be from the mix I have...
  1. Replies: 9
    Last Post: 01-06-2017, 01:44 AM
  2. Wanted: paint code plate w/ Conda green code
    By 9seriesguy in forum For Sale: 911 Parts
    Last Post: 11-05-2009, 07:33 PM
  3. Name that paint code..
    By budge96 in forum General Info
    Last Post: 08-08-2009, 10:55 AM
  4. how do I remove paint from paint code plate?
    By 911scfanatic in forum Technical Info
    Last Post: 10-26-2005, 06:00 AM
  5. Paint Code help
    By Paul in forum Technical Info
    Last Post: 06-20-2002, 03:42 PM
