Results 1 to 10 of 19
Thread: Running Too Rich?
    Jun 2003
    Bend, Oregon
    Running Too Rich?
    My '67 SWB is running great, except for one little thing - when I back off from high revs in 5th gear, say from 6,000 to 5,000, there's a little roughness for a short time. The feel is that things are loaded up a bit. I'm wondering if it's running a little rich. Here's the setup:
    o original 2.0 built to 2.7 specs
    o 901 "Solex" cams
    o 40mm PMO's
    o open venturis with tea balls
    o jetted for the 4,000' elevation that I live at
    I don't get any stumble when I'm shifting up through the gears, just when backing off from high revs in the same gear. It works through it in a couple of minutes. A little rich or something else?
    John Audette
    Dec 2006
    Las Cruces, New Mexico
    When mine did that it was a fuel pressure issue. I had to run dead on 3.5 PSI or would stumble/hesitate a bit when backed out then back in as you describe, very crisp and clean going up. IDA 40's on 2.5 SS same altitude.
    Early 911S member #166
    John,
    Mark is right on,.....
    JMHO, but Webers MUST,.................MUST get 3.5 psi of fuel pressure to work properly.
    There is a whole myriad of ills from incorrect fuel pressure and float levels so close attention to details is needed for these to run well.
    Hope this helps,
    Steve Weiner
    Rennsport Systems
    Portland Oregon
    503.244.0990
    Jun 2003
    Bend, Oregon
    Thanks guys. I haven't dealt with fuel pressure issues before. I'm running a Facet fuel pump rated at 2.75-4.00 PSI. Can I install something to regulate the flow at the pump or is it handled by installing some type of in-line regulator? Any recommendations?
    - JohnA
    Quote Originally Posted by jaudette3 View Post
    - JohnA
    Are you using the little solid-state Facet (square) or the electric (cylindrical) one?
    You need a low-pressure Holley regulator (0-5 psi).
    Steve Weiner
    Rennsport Systems
    Portland Oregon
    503.244.0990
    Jun 2003
    Bend, Oregon
    Quote Originally Posted by Steve@Rennsport View Post
    Are you using the little solid-state Facet (square) or the electric (cylindrical) one?You need a low-pressure Holley regulator (0-5 psi).
    Steve...
    It's the cylinder shaped one with a Bendix sticker on it - looks just like an original. Since I enter this car in shows from time to time I try to keep it looking as period original as possible. I'm wondering if there is a "stealth" way to mount the regulator. Right now the only thing between the fuel pump and the hard fuel line is a fuel filter. Perhaps I could replace it with the regulator and tuck it in the back and place the fuel filter in front of the fuel pump?
    Or maybe early competition cars did have regulators and pressure guages mounted at times? I do like the look of the pressure guage mounted in the center.
    Those are modern Facet pumps all right, you can tell by the wire. Looks like you have the ones with the 1/4" NPT fittings, and someone has cleverly adapted the M12x1.5 banjo fittings. Unfortunately, the most common one of those puts out 6.7 psi. . .I have a special one I ordered from a yacht supply place that puts out 4.0.
    Anyway, get yourself a "malpassi filter king" which is a combination of a filter and a pressure regulator, and you can even put a gauge on it. Get the one with the STEEL bowl. That can hide back on the firewall and nobody will see it.
    What coils are those, Summit? Accel? Those are cool.
    Jun 2003
    Bend, Oregon
    Thanks John - ordered the Malpassi filter/regulator combo. What a great solution.
    And thanks also to Steve and Mark. What a great forum - problem and solution identified in one day.
    Regards,
    John Audette
    Jun 2003
    Bend, Oregon
    Here's the filter/pressure regulator combo that I installed. I'm posting a link and a picture mainly for Tom Ching who asked about it in Palos Verdes - I can't find his email address.
    Cheers,
    JohnA
    A nicely made part that does the job well and reliably.
    If you have large needle valves fitted (the valve that the float shuts) then you may need to keep it below 3psi but normally 3.5 is ideal.
  1. FS: Battery powered 914 tin models police bump & go running/steerable 914 not running
    By 88cs in forum For Sale/Wanted: Other Porsche Cars and Parts
    Last Post: 02-12-2013, 07:38 PM
  2. 73 MFI running way too rich
    By caproader in forum Technical Info
    Last Post: 04-30-2009, 12:17 PM
  3. am I running rich???
    By 356robo in forum Technical Info
    Last Post: 09-20-2008, 11:48 AM
  4. running rich with carbs?
    By 37yrold911 in forum Technical Info
    Last Post: 08-31-2006, 04:02 PM
  5. Is it too Rich?
    By deoxford in forum Technical Info
    Last Post: 12-20-2004, 12:22 PM
