Results 1 to 8 of 8
Thread: Ball Joint to Boge strut housing problem
    Aug 2005
    Bucks Co., PA, USA
    A bit embarrassed to post this but in a bit of a dilemma.
    After I got back from Hershey I took my car ('70T coupe) to get inspected. Mechanic (primarily a VW guy but has a 912) found ball joint failure and loose strut housing. Previous mechanic prior to my ownership attached the Bilstein strut housings to the car with overlarge bolts, requiring replacement with Boge strut housings. (At least that's how he explained it to me.) Now current mechanic can't attach the new ball joints without some odd sized bolt: 9mm x 1.5 pitch, about 25mm long. He's had no luck sourcing these, called Fastenal who said they'd mill him a pair for $100. He suggested I call dC Automotive in NC which I did and got a voice mail message.
    Am I missing something here? Did someone use an oversize bolt on these used Boge housings?
    Car has now been in his shop 2 weeks today and has not been on the road other than to/from his shop since Hershey. Getting very frustrated. Oh BTW the Boge housings he sourced have Koni inserts; combined with my Bilstein rears this is turning into a real mishmosh and I see forking out more $ for either Koni rears or Bilstein inserts for the Boges to get everything matched up again. Grrr...
    ESR #1474
    Scope Creep Poster Child
    May 2003
    Eugene, Oregon
    The '70 struts attach to the ball joints with a simple pinch clamp. Perhaps the bolt in question is what pinches the strut housing around the ball joint stud. Starting in '71 (I think), the ball joints and strut housings were changed so that a tapered pin secures the ball joint stud (which now has a notch to engage the pin) to the strut housing. The earlier type of system has been known to fail. You can imagine how catastrophic that would be. The later type of ball joints and strut housings are a recommended upgrade. All of this is a way of saying that, if you still have the original style system, you might not want to go out of your way to make it work, and might want instead to invest in later parts.
    Early S Registry 1047
    ’15 VW GTI
    '70 911E, Sold
    '56 Cliff May Prefab
    Senior Member Macroni's Avatar
    Nov 2006
    Philadelphia PA
    No answers but hope you find a solution!
    86 Sport Purpose Carrera "O4"
    Teenchy, I'm afraid you are victim of previous owner's poor choice of parts. Up through 72 (Scott was close) the ball joint had a semicircular notch, the bottom of the strut was slit, and a 10mm partial shoulder bolt went through the strut, past the notch in the ball joint into a nut, and was then tightened clamping the ball joint tightly. In 73 the ball joint had a VEE groove cut in it, the bottom of the strut was NOT slit, and a tapered wedge was driven in and tightened with an 8mm nut to wedge it in tightly against the ball joint. None of these methods are interchangeable, the slit strut MUST be used with the proper ball joint and bolt, the later ball joint MUST be used with the wedge bolt. To the best of my knowledge Bilstein never made a strut for the early pinch style ball joint. To use that strut requires the later ball joint and wedge bolt. Hope this helps explain what you have.
    Aug 2005
    Bucks Co., PA, USA
    Ed, you hit it on the nose. The ball joints and struts in question are of the pre-72 variety and the botls are indeed 10mm partial shoulder bolts. Where he was getting 9mm from I don't know. Bolts have been sourced locally and the job should be done soon. This isn't the first time you've helped me pull my chestnuts out the fire; I think I might owe you something!
    Scott, I know these could fail but they'll have to do for now. I haven't read widespread stories of their failure so hopefully they'll get me through this driving season.
    ESR #1474
    Why take the risk? The later struts are cheap. It's the labor that is expensive.
    Aug 2005
    Bucks Co., PA, USA
    Point taken but who would buy all these parts from me? Only the struts are used, everything else is new and in the car, too late to return them. Have there been numerous bolt/strut failures, or have they all already happened and everyone's made the change, just like 911E hydropneumatic suspensions?
    ESR #1474
    May 2003
    Eugene, Oregon
    My information about failures came from Grady Clay. You might want to email him.
    ’15 VW GTI
    '70 911E, Sold
  1. Ball joint question
    By classic in forum Technical Info
    Last Post: 09-11-2011, 01:16 AM
  2. FS; Koni strut inserts, pn 86-1647 for Boge strut housings
    By m1franck in forum For Sale: 911 Parts
    Last Post: 03-08-2010, 09:19 AM
  3. What camber to run? Decambered Ball Joint?
    By 72Group4 in forum Technical Info
    Last Post: 02-21-2010, 04:09 PM
  4. Did the R use the old style ball joint
    By MarkS in forum Technical Info
    Last Post: 09-22-2009, 11:37 AM
  5. WTB: '72-73 Boge strut housing
    By fryardds in forum For Sale: 911 Parts
    Last Post: 03-26-2007, 02:49 AM
