Results 1 to 9 of 9
Thread: Spark Plug Gaps, MSD, smoothness
    I have a very sweet running 2.7 with a few mods and an MSD. For years I've heard that I should open up the spark gap to .045"--.050" (from the .032 I've been using) with NGK 6's. Steve Weiner and others have noted increased power and smoothness at the bigger gaps. Well I finally got around to trying this. Quite amazing. There may be more power, I can't really tell, but the motor is easily 20-30% smoother, at idle and at speed!
    Anyone know why? I'm guessing that a wider plug gap means that current is stored a millisecond longer and that perhaps more of it is released when the plug fires, but why would this affect smoothness? Whether or not anyone has the answer, increasing the gap has produced a very noticeable improvement with which I'm delighted.
    jhtaylor
    santa barbara
    Hi Jim,
    I'm very pleased that you took my advice and tried the big plug gaps,.. I don't offer something that I haven't tried and know to work as claimed,...
    The large plug gaps help create a larger flame kernel that burns hotter. This ensures more thorough fuel/air combustion in the small amount of time it has before TDC.
    The engine dyno doesn't lie and we see more HP with these larger gaps over the factory-specified ones. One simply must have an ignition system thats sufficiently powerful to strike and sustain the spark.
    Steve Weiner
    Rennsport Systems
    Portland Oregon
    503.244.0990
    Senior Member CamBiscuit's Avatar
    May 2006
    Adelaide, Australia
    Does this also apply to a twin plug system fired by a single MSD?
    Looking for engine # 6208151
    '74 RS 3.0 Replica
    '70 911E Bahia Red (SOLD)
    '71 911 S/T Replica 2.3 Twin plug BEAST (SOLD)
    Australian TYP 901 Register #78
    Early S Registry # 1076
    2.4T w/ MFI and Bosch ignition
    What does this mean with a 2.4T w/ MFI and Bosch ignition module? Am I to presume that they too require larger gaps? If so, how much?
    Olin
    I'm not an expert but my guess is no...probably because the Bosch doesn't send enough volts to jump a bigger spark gap. I think the factory would have gone for more power and smoothness if it could have been achieved so easily.
    jhtaylor
    santa barbara
    Volts to the coil:
    Bosch CDI - ~400 Volts
    MSD - ~500 Volts
    So about 25% more volts, which equates to about 10,000 volts to the cylinder using a standard 100:1 coil (40,000 vs 50,000). But you opened the gap by about 40-45% more. Maybe there is some room to open it up with the stock system.
    Olin
    I'm doubtful but you have little to lose. If it won't start, or your secondary wiring gives out, you'll know you've gone too far!
    jhtaylor
    santa barbara
    I always thought MSD stood for multiple spark discharge so you have a much better chance of getting a good spark at the plug.
    Jeff Eelkema
    69E (project)
    S Reg #1431
    Aust TYP 901 #132
    It does and you do (at least under 3k rpm...the multiple spark feature goes away at higher rpm.)
    jhtaylor
    santa barbara
  1. FS: Used spark plug tool
    Last Post: 07-23-2013, 09:43 AM
  2. FS: Spark Plug Tool
    By juche_namja in forum For Sale/Wanted: Other Porsche Cars and Parts
    Last Post: 06-15-2011, 07:19 PM
  3. 2.4S spark plug
    By cosley in forum Technical Info
    Last Post: 07-27-2007, 08:42 AM
  4. Question about Spark Plug Gaps
    By gruen911 in forum Technical Info
    Last Post: 07-23-2005, 07:38 AM
  5. What's the right spark plug to use in a 2.7RS?
    By JimR in forum Technical Info
    Last Post: 06-11-2005, 05:12 PM
