Thread: Front and rear glass removal
    Aug 2005
    VA
    Having the car painted this weekend. Plan is for me to take everything I can off, including the front and rear glass (windshield). Have the shop repair two small rust spots near the glass, prep / paint the car then have a new windshield installed by a third party and pay the guy to reinstall the rear glass as well.
    The front windshield is fogging on the sides so I want to replace it at this point. The rear is perfect.
    What’s the best method for getting the glass out?
    Should I be concerned if the glass company doing the install has never done a 73 Porsche before? In other words is there anything unusual about the removal and installation process?
    Many Thanks,
    Chris
    73 911 E
    Dec 2004
    "unusual?" Not really
    Run a plastice putty knife around the inner and outter lip of the seal to make sure it is free, squirk/mop some soapy water under the lip of the seal to act as a lube, working from the inside slowly/gradually work the edge of the rubber seal over the lip of the metal edge. Be careful not to apply too much pressure in any one place too soon as this may crack the glass. You will know you have it licked when you feel the glass and seal begin to move outward. Keep working your way around slowly to the very end, the glass and seal should come out as one.
    If the seals are relatively new, you will have little trouble getting the galss out. If the seals are very old and hard, you may have to cut away portions of the hard rubber to get the glass out. Go slow.
    Do you have the new seals? Be sure to buy NOS rubber for these two areas. I found a considerable difference between NOS seals and aftermarket seals. Teh aftermarket seals were narrow and did not cover well.
    Good luck.
    [SIGPIC][/SIGPIC]
    1967 911S Coupe
    1991 944S2 Coupe
    Past projects:
    1967 912 Coupe
    1969 911T Coupe
    1985.5 944 SR Coupe
    Jan 2003
    UK
    I personally wouldn't use anyone who has not done this (several times) before - the aluminium inserts which fit in the F&R rubber seals are easily bent.
    They need to be (carefully) removed after the screen & seal have been taken out then inserted into the new seal after it has been put around the screen but before the whole assembly is refitted to the car.
    Andy
    Early 911S Reg #753
    R Gruppe #105
  1. Replies: 1
    Last Post: 03-20-2014, 05:24 PM
  2. Glass Removal SWB Vent
    By 50/50 in forum Technical Info
    Last Post: 12-26-2013, 08:02 AM
  3. Front Vent Glass Window Removal?
    By TheBen in forum Technical Info
    Last Post: 11-16-2013, 03:37 PM
  4. Removal/installation door glass
    By denson in forum General Info
    Last Post: 12-07-2008, 09:58 AM
  5. VDO instrument glass removal
    By RS SIEG in forum Technical Info
    Last Post: 04-12-2003, 01:43 AM
