Thread: 67 Trunk floor bracket info
    I need some help with the brackets at the front of the trunk, in front of the battery box, for the washer bottle and pump.
    When the suspension pan was cut out the cut went through the smaller bracket. The larger bracket wasn't disturbed. Does anyone have pictures of that area that we can use to correctly make and locate that bracket?
    We're almost done with rust repair, once we start with mods I promise pictures.
    Alan
    Hi Alan-
    Is this what you are looking for?
    Scott
    Early S Reg. #1694/R-Gruppe #638
    74 Carrera
    here you go
    Exactly what I needed. Thank you gentlemen.
    Alan
    larger bracket
    Alan, you don't need this info on the large washer bottle bracket as yours is still serviceable but - for our records - I did this for another member needing it.
    Large Bracket size and shape.
    Bob
    Early S Reg #370
    Thanks very much Bob.
    Of course it was the bracket that will be harder to fabricate that we cut. With these pictures and the pieces that we have from the one we cut I'm sure we can make up an accurate part.
    On to more parts hunting.
    Thanks again,
    Alan
  1. WTB Floor Pan
    By timgt3 in forum Australia
    Last Post: 07-04-2013, 02:35 AM
  2. FS floor pan
    By jennetd in forum For Sale: 911 Parts
    Last Post: 09-09-2009, 08:50 PM
  3. need info on hood trunk lights
    By EARLY911ZOO in forum General Info
    Last Post: 10-26-2008, 05:28 PM
  4. Please help: need picture of floor bracket for battery strap
    By Anthony67_911s in forum Technical Info
    Last Post: 05-31-2007, 05:47 PM
  5. Trunk - Does this look ok?
    By 72911E in forum Technical Info
    Last Post: 08-15-2006, 09:15 AM
