Thread: Quick change seat mounts
    I'm talking to Stefan about mounting an Avus seat in my 74. I want the seat low, for tall passengers, and I'd like to be able to remove the seat easily for access behind it. Because it adds too much height, his hinged base is out.
    I've been thinking about fabricating a base using two pins on the rear of the seat, oriented along the axis of the car, which would engage holes in something attached to the seat floor. At the front, two more pins would be attached to the seat and set so they would drop into "sockets" of some kind attached to the car. The front pins would be secured by cotter pins. Anyone seen anything along these lines? Any thoughts welcome. jim
    jhtaylor
    santa barbara
    Oct 2008
    Burford, ON, Canada
    You might consider something like the 914 arrangement that allows tilt & reach while having a very low installed height.
    Aug 2003
    Van Nuys, Ca
    We fabricated a quick release mount for the passenger side of a tv use car. We used quick release pins- sometimes called pip pins, from the local aircraft supply store. They have them in various lengths and diameters
    Do not depend on the pins for bearing the weight of the seat and occupant. The pins should be used in such a way that you can slide the seat foreward and pull the rear pins up and out, then slide the seat back to remove the front pins. We had 8 bushings machined so the pins slid thru tightly and limited fore/aft movement.
    It takes a lot of time to get it right, but worthwhile as the stock 914 mountings are just on 3 points and very weak
    Member #755
    Conda Green 70 911S
    70 black 914-6 3.2
    70 911 "Speedster" project
    "74 IROC" tribute Jade Green RSR
    Thanks Dave. You don't have a picture of that set up do you? I'm not finding it easy to visualize what you did. Jim
    jhtaylor
    santa barbara
  1. FS: Seat frame mounts
    By cjtbt in forum For Sale: 911 Parts
    Last Post: 12-16-2013, 06:12 AM
  2. Relocating SWB seat belt mounts
    By buddeman in forum Technical Info
    Last Post: 05-31-2011, 08:01 PM
  3. WTB - seat mounts/sliders for my 73
    By X-Faktory in forum For Sale: 911 Parts
    Last Post: 04-15-2011, 09:18 PM
  4. WTB - Seat frame mounts
    By Polizei in forum For Sale: 911 Parts
    Last Post: 04-01-2010, 04:38 PM
  5. Peter Z R seat with recaro base change ability
    By spyderwerks in forum Technical Info
    Last Post: 11-26-2006, 03:12 PM
