Results 1 to 8 of 8
Thread: Anyone in Michigan able to look at car for me?
    Need to get a pre-PPI and rec. for PPI location for a car. Biggest concern of course is rust.
    Appreciate any assistance,
    Erik
    Erik
    Early S # 1107
    All my german equipment is either busted or sold...sigh....in the market for a decent non-sunroof tub!!!!!!! Help me get back to autocrossing!!!
    Update:
    Car getting pre-PPI looked at but could still use recommendation for PPI shop.
    Thanks!
    Erik
    Early S # 1107
    PPI in Michigan . . .
    Hi, Erik . . .
    I PPI'd a '71 'S' (VIN 91113000115) in Michigan about two years ago, before I found my car. I worked with Chris Braden at an outfit called Munk's Motors:
    http://www.munks.com/index.html
    HTH
    Rick Kreiskott
    Thanks Rick.
    Erik
    Early S # 1107
    Michigan Referrals
    Is the car in the Detroit area, another Jeff Jones, owner of Automotive Techniques, Novi MI, (248)615-8964
    If you may need shipping, a local PCA and 356 Registry member has a transport company Joe Jakubus, Jakubus Transportation, (734) 837-1118.
    Joe does the "transporting" himself and he has an outstanding reputation.
    I sent you a private message.
    Dave
    Sunshine State
    Unfortunately, nothing but bad experiences with all Michigan/Detroit area shops in regard to EARLY 911's. Example: one of the shops mentioned here charged a friend 1-hour labor to "research" how to remove the rocker trim from his car. Not sure what is worse, the 1 hour labor charge or the fact they had to actually research it I could go on and on with similar stories on pretty much any shop you can name around here.
    I tow my car 7 hours and across 2 state lines for service.
    Thanks Curt/all. Have a Pelican looking the car over today who has actually built some motors so have asked if he can do mechanical PPI if car looks good tub-wise.
    Comes down to me and a magnet and awl i suppose!
    Will likely be trailering car back myself if i do buy.
    Erik
    Early S # 1107
    Dec 2004
    SE Michigan
    I will be around this w/e and might be able to act as another set of eyes. I am in the Rochester area in northern SE MI. PM me if you want.
    Bill G.
    EarlyS #718 | RGruppe #437
  1. Ferrari find in Michigan
    By hoffman912 in forum Other Car Cultures
    Last Post: 01-09-2012, 06:14 PM
  2. West Michigan Round Up
    By 911_S/T in forum Drives, Tours, Gatherings, Racing and Adventures
    Last Post: 09-19-2011, 11:34 AM
  3. First Drive Of The Year in Michigan.
    By 911_S/T in forum General Info
    Last Post: 02-18-2011, 11:14 AM
  4. Painter Needed in SE Michigan
    By rpsurfr in forum General Info
    Last Post: 05-11-2009, 03:31 PM
  5. Michigan Guys Only ...
    By CurtEgerer in forum Off Topic
    Last Post: 02-22-2006, 04:39 PM
