Results 21 to 30 of 39
Thread: '68 was rear ended, picture inside
  1. #21
    Dec 2003
    West Los Angeles
    Unless your foot was off the brake, that looks like no more than a 7 MPH impact. There are very few cars that wouldn't be totaled in a 30--40 MPH impact.
    The rear bumperettes are attached in a way that allows them to deflect a little at the top; more at the bottom. An impact at the top of the bumperettes drives them into the panel supporting the slam panel and can carry into the box sections on either side of the engine. They in turn can 'push in' to the yoke that carries the upper shock mounts. In a vintage unit body car like a 911/912, the impact does not 'crumple progressively' like a newer car. So a rear impact (10 MPH plus) will potentially close the rear door gaps -- momentarily, chipping paint off the rear edges of the doors. This is generally as far forward as it goes, but on a coupe, look for a buckle alongside the end of the driprail on each quarter. When/if you see that, you've crossed into 5 figures.
    techweenie.com
  2. #22
    Pm sent Scott. Shop is Midwest Eurosport but don't want to publicly post the guys name without his permission.
  3. #23
    Update: repair bill is now up to $7100, two new SSI's and a M&K stainless muffler are now part of the deal. Still do not know if unibody is tweaked and how bad....
  4. #24
    Aug 2006
    Chicago area
    Yikes - good luck. And good deal on the SSI's and sport muff.
    Scott H.
    1969 Coupe LtWt
    1973.5 911T
  5. #25
    Mike, look on the bright side. . . this photo shows which way the energy goes
  6. #26
    I do not understand this. A good shop would determine this before anything. Perhaps you should find another shop IMO
    Early 911S Registry #750
    1970 911E - The Good Stuff
    2001 Toyota Landcruiser
  7. #27
    Yikes John that red car is munched! That is WAY worse than mine.
    Yes, I thought it was kinda odd that they haven't checked my car for straightness yet also. They like to order all the parts before they do that. I trust them, they fix a lot of tweaked 911 racecars and such.
  8. #28
    Update: my 68 is not tweaked, unibody checked out ok!
    I should have it back in a few weeks.
  9. #29
    That is great news Mike, what was the shifting problem?
  10. #30
    Ed, the car shifted fine after the hit, it was the starter that stopped working. Shop says it's been working fine now. So may have been a case of heat soak/old starter syndrome.
  1. FS: inside rear view mirrors
    By speedo in forum For Sale: 911 Parts
    Last Post: 11-30-2013, 06:35 AM
  2. 73.5 rear spoiler picture
    By LV911 in forum General Info
    Last Post: 07-24-2013, 05:09 AM
  3. FS Inside Rear View Mirror for LWB
    Last Post: 02-05-2011, 08:22 AM
  4. WTB: cup in inner rear fender (see picture)
    By preS in forum Technical Info
    Last Post: 08-23-2008, 07:32 AM
  5. 1965 Inside Rear mirror
    By ydderf911 in forum For Sale: 911 Parts
    Last Post: 05-22-2008, 11:06 AM
