Results 1 to 7 of 7
Thread: Q for 915 Gearbox Guru's
    Senior Member HughH's Avatar
    Dec 2004
    Melbourne Australia
    there is a lot of information on this board about typ901 and typ911 gearboxes and the special versions of them. however i cant recall ever seeing much about the special versions of the typ 915 gearbox - save a little bit about the variants fitted to the production RS cars.
    I have been waiting to ask this question for about a year after seeing the numbering on the gaerbox in the 1972 Monte ST that Leon has - see thread here
    the gearbox is numbered 915 033 (see attached pic from the thread) - this can only be a type number as far as I can see - not a serial number a that would a seven number series starting with 7, i have not seen a reference to a type number anything like it , or any competition 915 type numbers for that matter, despite looking for it over the past year or so.
    can anyone add any information - it is obviously a special competition box with oil cooler and very short gears.
    Hugh Hodges
    73 911E
    Melbourne Australia
    Foundation Member #005
    Early S Registry #776
    Port Macquarie, Australia
    Hugh, I reckon Grad Clay (normally on Pelican) would be able to help...
    John Forcier
    EarlyS #1987
    Restoration Saga
    Is it not the pairing number? Why would the type number be stamped in twice, symmetrical?
    Richard
    Dec 2004
    Melbourne Australia
    richard
    I really dont know
    it is a VERY early 915 box though and a very special one. it may be a coincidence to be numbered 915 but i suspect not given the car it is in.
    I dont know much about gearbox numbering and even less about what might be stamped on a competition box for a factory rally car so i am really putting it out there to see if anyone knows - if anyone does it is likely to be on this board
    Hugh Hodges
    73 911E
    Melbourne Australia
    I always thought Type Numbers (the number after the "/") were two digit numbers - i.e. 911/XX, 901/XX, or 915/XX).
    I agree with the previous statement that the numbers you posted, Hugh, are pairing numbers.
    -Marco
    TLG Auto: Website
    Another person that might know is Gordon Ledbetter (gled49).
    Randy Wells
    www.randywells.com/blog
    www.hotrodfilms.com
    Early S Registry #187
    those numbers are stamped on the opposite side of the gearbox. are there any numbers on the bottom where the clutch cable goes thru. I am going to bump gearbox # cannot be traced back as it is a ST trans, maybe some info there. Gordon
  1. question for the solex guru's
    By preS in forum Technical Info
    Last Post: 03-17-2011, 11:57 AM
  2. steering wheel guru's .....
    By nickd in forum Technical Info
    Last Post: 07-22-2009, 02:30 AM
  3. Numbers Guru's...Name This Plz!
    By Paul Schooley in forum General Info
    Last Post: 04-27-2007, 08:43 AM
  4. Input needed from MFI guru's
    By MarkS in forum Technical Info
    Last Post: 03-29-2007, 01:56 PM
  5. Electrical Guru's Unite
    By Neunelfer in forum Technical Info
    Last Post: 09-30-2006, 10:43 AM
