Results 1 to 10 of 11
Thread: corrosion
    Senior Member Cliff's Avatar
    Mar 2006
    8903one
    corrosion
    Anyone know how to treat the engine case for corrosion? Mine has some soft removable corrosion,(white fluff) with some surface damage that I need to address...
    Thanks,Cliff
    Restoration newbie.
    Jun 2007
    San Francisco
    Gibbs Brand makes some impressive claims.
    I am ordering some to protect my fan and housing.
    andy
    67S in pieces
    EarlyS: 1358
    [SIGPIC][/SIGPIC]
    Mar 2006
    8903one
    You know, I bought some aerosol oil some time ago from them, is that what you are referring to? or is there another item that they use for corrosion ?...Cliff
    Restoration newbie.
    Jun 2007
    San Francisco
    All I know is the product is called "Gibbs Brand" and it comes in various quantities
    from pumper bottles to aerosol cans to drums. If it does what it claims then I'm
    not expecting any corrosion to the aluminium surfaces.
    andy
    67S in pieces
    EarlyS: 1358
    [SIGPIC][/SIGPIC]
    Mar 2006
    8903one
    I just looked at the link;that`s what I got...Thanks for the reminder....Cliff
    Senior Member aporschaguy's Avatar
    Feb 2005
    Great White North
    I use Gibbs Brad on my Mag case and tranny. Worked great it restored the case to a nice dark color.
    If the engine is apart I strongly recommend having the case washed in a parts washer first.
    "He has all the virtues I dislike and none of the vices I admire."
    1971 911e
    1978 911sc Targa (Sold)
    1973 911 RSR (Clone)
    " IT doesn't Eat Rust, IT REVERSES the effects of oxidation! GIBBS® is a product whose time has come. It's in a class of it's own, a separate breed!"
    Whilst I am sure it works to an extent some of the claims are a bit wild! Clearly a strong reducing agent.
    May 2006
    CT
    If the engine is apart and the case has been split, Ollie's will tumble it. This will remove all the corrosion and make it look new.
    Soda blasting also works well but not as good as tumbling.
    Protect with Gibb's after removing all the corrosion.
    Tom Butler
    1973 RSR Clone
    1970 911E
    914-6 GT Clone in Progress
    Senior Member 210bhp's Avatar
    Feb 2004
    Scotland
    Wasn't Tectyl the original product used by Porsche on engine and gearbox cases?
    Mike
    RS#1551(sold)
    67S
    Early S reg. #681
    CRC makes a Corrosion protector very similar to Tectyl. It dries to a waxy dark film just like the Tectyl
  1. Front Hub Corrosion!
    By 304065 in forum Technical Info
    Last Post: 02-07-2010, 05:11 PM
  2. Weber white corrosion
    By 1QuickS in forum Technical Info
    Last Post: 09-15-2008, 07:02 PM
  3. Battery Corrosion - Replacement??
    By jcarpio in forum Technical Info
    Last Post: 02-13-2007, 01:43 PM
  4. corrosion protection
    By John Fusco in forum General Info
    Last Post: 11-25-2004, 04:35 PM
  5. Corrosion Repair
    By heirplane in forum Technical Info
    Last Post: 02-12-2001, 04:09 PM
