Page 2 of 3 FirstFirst 123 LastLast
Results 11 to 20 of 22
Thread: 911R - rear decklid hinges - oil filler position?
  1. #11
    Senior Member teveo's Avatar
    Jun 2008
    upper east side
    Quote Originally Posted by varunan123 View Post
    hope you temporarily mounted tank,the original is a snug fit.Looks good.
    raj
    Thanks, no tank yet. Looking for a complete 1972 system. I suppose I have to modify the 72 tanks filler neck and hopefully it will fit.
    The position is somwehat yours and KJ's measures "interpolated". The edge is too hard to bump so I am planning on building up with a flexible ring and JB weld. Not exactly like the pic but somewhat.
  2. #12
    Thanks Raj.
    The second prototype is all set and done, shown at the end of the thread. I am working on a third tank now which should cover all the little details of this mysterious tank. Trying to get it as exact as possible.
    Teveo, if you go with the 72 tank option I can help with the Blau received and cap if needed.
    Best regards,
    Brad
    Brad Davis
    RGruppe #691
    Early 911S #1547
  3. #13
    Senior Member Rico's Avatar
    Mar 2005
    Fort Lauderdale, FL
    Gentlemen,
    Question....
    Aren't the finned "R" oil tank caps supposed to be 70mm?
    It seems that 70mm to 90mm have been mentioned.
    My finned gas cap is 100MM. (seems too large for the oil fill)
    I'm about to do this mod on my 72 shortly and want to confirm.
    Thanks.
    Steve
  4. #14
    Mar 2005
    Fort Lauderdale, FL
    no advice.....anyone....
    Steve
  5. #15
    Jun 2008
    upper east side
    My cap is around 85 mm outer diamater, the hole is around 94 mm and the fit looks ok.
    Hole is still a little crude, will trim it a little and it will perhaps be around 96 mm when finished.
  6. #16
    Jun 2008
    upper east side
    The doors are being adjusted and they'll be nice with polycarbonate windows, leather straps and so.. I'll be using Ernie W.'s pix of Raj's car and try to duplicate the look of those.
  7. #17
    Mar 2005
    Fort Lauderdale, FL
    Thank you Raj for that insight.
    Steve
  8. #18
    Jun 2008
    upper east side
    Finally bonded the front fenders, would anyone have the correct measures here? I used photoshop and the ruler tool to estimate. I think I got the holes right but have to work with some pix from the side as well to get the park and flasher in space.
  9. #19
    Jun 2008
    upper east side
    I mocked up and think the holes came in fine, I may have to move the park and flasher closer to the air holes though. The mobilcam does not make a vey good pic.
  10. #20
    Jun 2008
    upper east side
    Some progress last month.
    Centerfill
    Trial fitting of the bucketseats
    Some fitting of fenders still left, then off to the paintbooth.
  1. 911R Decklid Hinges
    By sam71TargaS in forum For Sale: 911 Parts
    Last Post: 06-27-2010, 08:10 PM
  2. 911R Rear Hinges
    By ydderf911 in forum For Sale: 911 Parts
    Last Post: 04-07-2009, 08:20 PM
  3. 911R rear hinges
    Last Post: 02-16-2009, 05:37 AM
  4. WTB: 911R rear hinges
    By Mark Morrissey in forum For Sale: 911 Parts
    Last Post: 01-26-2009, 05:40 AM
