Page 1 of 20 12311 ... LastLast
Results 1 to 10 of 199
Thread: What makes a 1969 911 unique?
    Senior Member beh911's Avatar
    Aug 2009
    Atlanta
    Folks,
    After researching the 69 MY on this fabulous site, I had this idea for a thread: How about an attempt at an evolving, definitive thread for all things unique to 69. Not only was the this year a 'first' for Porsche on a number of somewhat obvious fronts (longer wheelbase comes to mind), but it was also a year of 'onlys', as well as 'firsts and onlys' and 'lasts' (wasn't the MFI pump unique to 69?).
    My thoughts for the thread are on the objective side, but opinions on 69 uniqueness are fine. So any parts (unobtanium, NLA, readily available) or one off design attempts by the factory and the reason or opinion for change are welcome. The posts could be across T,E, and S cars, but an S emphasis is most interesting (to me at least). Basically, I want to learn from this knowledgeable group of enthusiasts, so please indulge me .
    Pictures and part numbers, opinions on scarcity or newer alternatives are all welcome. References to other threads would be great as well.
    I'll start with a few I found today:
    The clutch disk is unique and scarce, NLA from Porsche:
    http://www.early911sregistry.org/for...69-clutch-disk
    The rear decklid was unique according to this thread, starting mid year 68 and ending in 69:
    http://www.early911sregistry.org/for...2-rear-decklid
    OVERALL THREAD SUMMARIZING BEGINS HERE:
    http://www.early911sregistry.org/for...l=1#post517702
    Sources include contributors on S Registry, The Porsche911 Story by Frere, and Excellence was Expected by Ludvigsen
    The 67 and 69S are the oddball vehicles that make them unique. The MFI on the 69S was the first one put on a 911. It is also the only one put on the 2.0 liter engine. It went to 2.2 in 1970. The 69 is also the only LWB with the 2.0 engine in it. I think the 69 was the first year to use 2 6 volt batteries for weight distribution. Please check me on this one
    First year for dual batteries, revised heat/fresh air system, CD ignition on E and S, hand throttle, flip out door map pockets, new style ball joint, VIN on riveted plate on A pillar, fuel vapor collector under cowl, 6" wheels, aluminum S frt. calipers, sealed rear axle bearings, glue on inside rear view mirror, front vent windows became fixed, horn grills were smaller, first production use of front oil cooler, black wiper blades and arms, and a one year only wiring harness.
    Saved the best for last, eh?
    -Marco
    TLG Auto: Website
    Ah yes Marco, you've been there haven't you
    Just to clarify NV Stig's comments, MFI was also fitted to 69Es
    Jeff Eelkema
    69E (project)
    S Reg #1431
    Aust TYP 901 #132
    Jeff is right! I had to check on that, but he is spot on. I guess that goes without saying when you have an E I didn't know that tid bit, I learned my one thing for the day. Also, 69 was the first year for the magnesium crank case.
    Port Macquarie, Australia
    Three bar engine grill (1 year only)
    And I stand to be corrected, but wasn't it the only year the "soft window" targa was produced?
    John Forcier
    EarlyS #1987
    Restoration Saga
    #2264 classic's Avatar
    Nov 2004
    Gold Coast.
    Last year that they used Webber Carbs 69T
    First year for bright dip alloy window frames
    3 bar engine grill 69 only. Correct me if i'm wrong on that one?
    Unique sun visors
    Introduction of Gas burner wheels
    Introduction of the Hella 169 fog lights
    Nov 2004
    Gold Coast.
    You beat me on that one John
  1. Unique Calipers on a 1967 911...
    By Neunelfer in forum Technical Info
    Last Post: 08-01-2013, 02:45 PM
  2. Unique Turbo for Sale
    By RTincher in forum For Sale/Wanted: Other Porsche Cars and Parts
    Last Post: 12-25-2009, 07:46 PM
  3. Unique and spectacular 912!!
    By mjk911 in forum For Sale/Wanted: Other Porsche Cars and Parts
    Last Post: 04-20-2009, 09:17 PM
  4. Unique 7R fuch details
    By Alan.uk in forum Technical Info
    Last Post: 03-08-2008, 01:59 AM
  5. Here is a unique car: 69 MG with Chevy V8!
    By gruen911 in forum For Sale/Wanted: Other Porsche Cars and Parts
    Last Post: 07-21-2005, 06:28 AM
Message Board Disclaimer
