Page 1 of 9 123 ... LastLast
Results 1 to 10 of 81
Thread: 68S with race details?
    Oct 2010
    Sweden/Canada
    68S race car? Help me with the details please!
    I bought this 68S in really rough condition earlier this year. Lots of bodywork needed but all I could see was a redline at 7200, matching numbers aluminium engine and an interesting set of options. So I went for it.
    Many mods have been done to the car over the years and I have a really hard time figuring out what is original and what are later mods.
    It also turns out the car is rumoured to have been a race car in its early life, and there are some details that could support this claim. I would very much appreciate your opinion on these details, if only to clarify that they have nothing to do with race use!
    I have attached some pics, please let me know if there are other areas/angles I should photograph.
    * The white button is the starter. Is that really how they were originally? There seems to be a "starter position" on the ignition lock too, but not connected.
    * What is the little pull button above the ignition lock for?
    * What can the hole between the oil instrument and the tachometer have been for?
    * There were cover flaps like these on both sides, see next pic what is hiding underneath.
    * Is this long haired carpet standard or an 80's addition? It seems to be glued onto the horsehair underneath.
    * This is what is under the flaps, other side (right) in this photo. Three larger holes and one smaller. What has been attached here?
    * This anti-roll bar attachment looks weird, home made?
    * Nadella shaft, should a 68 not have the later Löbro CV joints?
    * Bendix pump right? Again, should a 68 not have the later Hardy type pump?
    I am sure I will come up with more, but this is what I have now. Thanks in advance for your input!
    Restoration newbie.
    Jun 2007
    San Francisco
    Sent you an email Mikael. Nadellas most likely indicates you have an
    early ZF LSD in that transaxle.
    andy
    67S in pieces
    EarlyS: 1358
    [SIGPIC][/SIGPIC]
    Aug 2006
    Sonoma, CA
    It looks like a SWB rear sway bar and mounting bracket s have been adapted to fit a car with LWB Banana arms
    johnt
    Sep 2006
    La Quinta
    Looks like some one has put a "Dead Pedal" in.
    1962 356 Cab, show car, sold.
    Registry #983
    R Gruppe #741
    Oct 2010
    Sweden/Canada
    Quote Originally Posted by ajwans View Post
    andy
    Andy, that makes sense as according to the CoA information it was equipped with a LSD. I have yet to check if it's still in the car though.
    Quote Originally Posted by JohnT View Post
    johnt
    Ah, that may be the case. Saw/heard someone mentioning that maybe it was converted to LWB at some point. Apart from measuring the wheelbase, are there any telltale signs of LWB? Can I determine from looking at the banana arms? Sorry if this is a stupid question, this is my first SWB!
    Quote Originally Posted by John Straub View Post
    The foot rest was an original option to the car. Here's the CoA information:
    Chassis number: 11800524
    Engine number: 4080594
    Gearbox number: 4280597
    Color 6809=tangerine
    Interior: leatherette black with Pepita
    Date of invoice 19.Dec.'67
    Dealer: Winter, Berlin
    Options: additional heating Webasto, warning light, towing hook, limited slip differential, foot support left and 3-point seatbelts.
    Motor is the one mentioned above, type 901/02 with build # 11608. I have not been able to find the gearbox number, it seems to have been worn off. Is the gearbox number to be found anywhere else? According to the number above it should be a 901/02 gearbox, standard S with AFMSZ gears and 7:31 LSD.
    Btw, what is the warning light they mention?
    Maybe thats the hole between the gauges a larger oil pressure warning light perhaps. S
    Jan 2011
    DFW TX
    If you have LWB trailing arms in a SWB car, the rear wheels will not be centered in the wheel wells.
    Sep 2008
    Monza, Italy
    Quote Originally Posted by chiroracer View Post
    I agree. classic Idiot light position.
    Interesting car, Mikael!
    Registry Member #1414
    NOSGRUPPE
    Oct 2010
    Sweden/Canada
    Could be. Are there examples of this somewhere to have a look at?
    Quote Originally Posted by M_deJong View Post
    I'm afraid my wheel wells aren't much of a reference here, 935 plastic. I'm almost ashamed to show her, but this is what she looks like right now:
    Dec 2006
    Las Cruces, New Mexico
    If it was raced and or hacked on may have centered up when installing flairs.
    Early 911S member #166
  1. 68S with race details?
    By mikael in forum Technical Info
    Last Post: 12-07-2012, 09:48 AM
  2. 1967 911 Vintage Period Race Car, 40 Year Race Career
    By Rennman in forum For Sale/Wanted: Early 911 Cars, 1965 - 1973
    Last Post: 09-06-2012, 07:13 AM
  3. Details Details! Which Speaker Grille Is Correct For A 1969-1973?
    By execmalibu in forum For Sale: 911 Parts
    Last Post: 06-22-2008, 06:54 AM
  4. Lights and hood, the details, the details..........
    Last Post: 08-22-2006, 02:17 PM
