Results 1 to 10 of 19
Thread: Best tire size for a 73 with 7s ??
    I am ready to install some 7s on all four corners of my standard body 73. I would like to put a "traditional" looking tire the same size all the way around. I am thinking Pirelli or Michelin. I am not looking to lower the car or use a low profile tire. Has anyone done this? Thanks guys.
    Don
    7's are going to be tight on the front, are these 15's or 16's. I'm running re-11s on 6x16 front and 7x16 rear. With the new sticky compounds you really don't need wider tires than that, and I've got a 2.7 RS spec motor.
    They are 15s which came on the RS so I am not worried about the front as much as the rear. Thanks.
    Don
    I have 205/55 BFG's on my 7x15's (front). No issues.
    Dave Pugh
    '73S #493
    RGRUPPE #627
    http://pughmedia.tumblr.com/
    Senior Member aporschaguy's Avatar
    Feb 2005
    Great White North
    I have 205/60s on my rear with a little sexy Negative camber on 17s...
    "He has all the virtues I dislike and none of the vices I admire."
    1971 911e
    1978 911sc Targa (Sold)
    1973 911 RSR (Clone)
    Thanks guys. Tom that is what I am looking for. Thanks.
    Don
    Don, I have Bridgestone RE9's on my 72s with 7" rims, 205/60-15. The fit, especially in the rear, is VERY tight. The choice for 15" tires gets smaller every year.
    Bahia Red '72 911S
    Meerblau PTS 2019 Speedster
    ES #333
    Senior Member NickP's Avatar
    Mar 2006
    Solana Beach, CA
    Tom, those are perfect. I have 7's on the rear and 6's up front, freshly redone by Harvey; will those 185/70's work on the 6's?
    Nick
    Nick Psyllos
    S Reg & R Gruppe
    1973 Euro 911S
    1972 911T to ST
    Don this is a 7R on a SWB, the tire is a Goodyear Eagle GT 195 X 65. I also have a set on my 72. I like the look of the tire size and the tread pattern, and they are V-rated, hard to find in a 15 anymore.
    Quote Originally Posted by NickP View Post
    . . . will those 185/70's work on the 6's? . . .
    That's the OEM size called out in my manual.
    The XZX's are also properly speed-rated for 150 MPH . . .
    One more thing. $400 a corner.
    And don't forget the spare.
    Rick Kreiskott
  1. 5.5x15 Tire Size
    By prez! in forum Technical Info
    Last Post: 03-28-2014, 03:55 PM
  2. tire size rsr 73
    By gwilliams in forum Technical Info
    Last Post: 12-08-2011, 06:01 PM
  3. Original tire size
    By Strato 102 in forum Technical Info
    Last Post: 07-23-2009, 07:49 AM
  4. 67S tire and size
    By mwilson3003 in forum Technical Info
    Last Post: 09-03-2007, 09:42 AM
  5. Best Tire Size for a '72 S Targa
    By RC70SCoupe in forum Technical Info
    Last Post: 09-26-2006, 05:55 PM
