Page 1 of 17 12311 ... LastLast
Results 1 to 10 of 169
Thread: Rudy's Rehab
    Rudy's Rehab
    Rudy is a very respectable numbers matching "driver quality" example that had been repainted about 20 years ago...and shows no visible signs of any rust issues. Since the engine, trans, suspension, and brakes have all be completely redone over the past 5 years, it's finally time for a complete bare metal paint job.
    So...let the fun begin!
    Cheers!
    Frank Kohnen
    Jupiter, FL USA
    Registry Member #921
    1972 Bahia Red 911 Coupe #9112100390..."Rudy" SOLD
    1967 Savannah Beige VW Beetle Sedan #117364457..."Heidi"...aka "Tinker Toy"
    Week 2 Update
    Dismantling/Stripping continues.
    "these cars have the tendency to rust from the inside out"
    So far...we've found rust in bottoms of both front fenders, lower section of both door skins, right and left rocker panels, lower section of both b-pillars, right and left sides of the rear package shelf, lower right corner of the windscreen frame, and the right and left rear seat pans.
    Stripping of the shell is next.
    Cheers!
    Frank Kohnen
    Jupiter, FL USA
    9 weeks (and 190 labor hours ) into the project...metal work nearing completion.
    Replaced inner and outer rockers on both sides, cut off and patched lower 6" of both door skins, cut out and patched both rear seat pans, cut out and patched lower section of both front fenders, cut out and patched rear shelf, cut out and patched right side lower corner of windshield frame.
    Next step...body work.
    Cheers!
    Frank Kohnen
    Jupiter, FL USA
    Here's Andy doing what he does best...
    Cheers!
    Frank Kohnen
    Jupiter, FL USA
    After 17 weeks and 400 hours of labor....the metal work is done and the body work is nearing completion. Next up...priming....block sanding (x 3)....color coats (x4)...sanding....polishing....reassembly. The color coats will be shot with Glasurit single stage in Bahia Red...exactly as it left the factory 40 years ago.
    Projected completion is mid-January (6.5 months start to finish).
    Thanks to all of the metal work that was required, the project will wind up taking 2 months longer and a lot more $ than originally planned, however, the end result should be spectacular!
    Cheers!
    Frank Kohnen
    Jupiter, FL USA
    Senior Member mimimemegna's Avatar
    Nov 2007
    Sanremo Italy
    Nice job... good luck!
    Maurizio G.
    Early S Registry member #1253
    1968 MY 1969 Light Ivory 911E
    Week 18 update
    Metal and body work completed...finally!!! Body is now primed and guide-coated and ready for the first round of blocking. Restored dash and door pockets back from Tony along with one of his new carpet kits. Restored Fuchs back from Harvey. Engine and trans headed to Phil & the gang for some maintenance. Restored Blaupunkt back from Radioman. Lots of new exterior bits on hand and waiting patiently on the shelf.
    This is getting exciting!!!
    Cheers!
    Frank Kohnen
    Jupiter, FL USA
    Jul 2008
    South Florida
    Good on ya, Frank... constant progress takes away a bit of anxiety, yeah? You'll really be itchy once re-assembly is underway!
    Looking forward to seeing Rudy after the facelift.
    Russ
    ESR # 1537
    '62 356S Notchback Hotrod
    '67 S Das Geburtstagsgeschenk
    '68 T Targa Sportomatic
    '68 L SW Targa Sportomatic
    '70 914/6 GT
    Thanks for your words of encouragement Russ...this project is really testing my patience!
    Cheers!
    Frank Kohnen
    Jupiter, FL USA
    well done Frank, those 400 hours so far will be worth every minute! I'm sure you're looking forward to seeing it in colour.
    cheers, Mike
    Member#1664
    1972 911 S/RSR to Martini Prototype specification
    http://www.ddk-online.com/phpBB2/viewtopic.php?t=15294
  1. Rehab of front chassis ID plate
    By AlfaGTA in forum Technical Info
    Last Post: 11-01-2009, 10:50 AM
  2. Fuel System Rehab
    By lwalwa in forum General Info
    Last Post: 05-15-2007, 06:48 PM
