Page 63 of 81 FirstFirst ... 1353616263646573 ... LastLast
Results 621 to 630 of 809
Thread: Light Yellow ST in Progress
  1. #621
    Quote Originally Posted by Harvey Weidman View Post
    Makes them look like vintages photos....Change them to B&W....
    H
    Here you go Harvey...even cropped the date out.
    Gib Bosworth
    EarlySReg 434
    R Gruppe 17
  2. #622
    Here are some shots Marco sent from Le Mans with the Toad Hall ST in the Porsche Classic display area. Marco with Hurley Haywood and Derek Bell. Also a shot of the #1 and #2 P1 Hybrids in the pit area.
    Gib Bosworth
    EarlySReg 434
    R Gruppe 17
  3. #623
    Going back through some of the pics I have taken...here are a few of my favorites.
    Gib Bosworth
    EarlySReg 434
    R Gruppe 17
  4. #624
    Got a very nice surprise in the mail today...
    Porsche Classic commissioned Spark to produce a run of 500 1:43 Toad Hall ST models to commemorate the display of this famous 72 911 ST at Le Mans and CLM this year. Marco sent me one...thank you Marco!
    These models are amazing in the minute details. A very special collectible.
    Gib Bosworth
    EarlySReg 434
    R Gruppe 17
  5. #625
    Senior Member Darren65's Avatar
    Quote Originally Posted by letsrollbabe View Post
    .....These models are amazing in the minute details......
    I'm not so sure Gib, the build on that model looks way too sharp for a race car!
    But then Marco's car also looked damned pretty at CLM .....
    .....would have looked even better on the race track!....
  6. #626
    Thumbs up
    But then Marco's car also looked damned pretty at CLM...
    It did indeed..........
    Hey Chuck,
    If I knew you were coming I would have brought a cake!
  8. #628
    Hey Chuck,
    Thanks Darren and sorry, lots of connections I missed out on this time... ... But maybe next...
    Cheers bud,
    cm
    I will be taking the 67 aluminum case 2.7L engine in this ST apart soon to build a twin plug 2.7L MFI engine with Mahle 90 mm 10.3 CR P&Cs. I have been debating this change for some time, and while it is hard to tear down a great running engine, the LY ST deserves to have a twin plug MFI engine making wonderful sounds. The list of 72 STs we have seen on the Ultimate ST thread shows the factory built 2-2.7L twin plug engines toward the end of the run for these special competition cars.
    The early aluminum case will need to have bosses added for the MFI pump, so it will go to Ollies for that work, and it will be an opportunity to freshen all the components. The Mahle 90 mm P&Cs are pretty special, and have the cylinder skirts 'mooned' for better cooling like all the race P&C kits. The 90 mm 10.3 Mahles were only available through the Racing Dept. in the day, and have recently been rarely made available. They are designed for the standard 2.7 head combustion chamber so that no additional work is required to keep their CR as specified unlike the 92 mm Mahle sets which require head work to prevent a very high CR unless you have the very rare 2.8L heads.
    Gib Bosworth
    EarlySReg 434
    R Gruppe 17
  10. #630
    Feb 2011
    Northern VA
    Gib
    Since those 2.7 ST's were '72 and pre-date the '73RS, I thought that they might have built them using parts on the shelf: a set of 2.5 89mm short stroke ST PCs used with a 70.4mm crank (instead of a 66mm) = 2.7.
  1. Light Yellow 73.5 T Targa - $26,000
    By res0ca5d in forum For Sale/Wanted: Early 911 Cars, 1965 - 1973
    Last Post: 05-29-2011, 08:01 AM
  2. SF Bay Area - Any Light Yellow (117) cars?
    By Ted_S in forum General Info
    Last Post: 07-01-2010, 09:37 PM
  3. Signal yellow with light yellow undercoat
    By Mark Wilson in forum General Info
    Last Post: 03-11-2009, 11:16 AM
  4. 1973 Light Yellow 911E
    By aknatar in forum For Sale/Wanted: Early 911 Cars, 1965 - 1973
    Last Post: 10-25-2006, 09:43 AM
  5. Light Yellow cars..
    By YTNUKLR in forum General Info
    Last Post: 08-08-2004, 01:35 AM
