Page 23 of 81 FirstFirst ... 1321222324253373 ... LastLast
Results 221 to 230 of 809
Thread: Light Yellow ST in Progress
  1. #221
    Senior Member uptheorg's Avatar
    Apr 2012
    Scarsdale, New York
    A shoutout to Gib -- I just read the thread and found it massively enjoyable and educational. Thank you for the time you spent making the posts -- and for everyone else chiming in with excellent tidbits, thank you too!
    Jim
    __________________________________________________ ___________
    Early S Registry #2359
    1970 Porsche 911 Rally 2.4
    2018 Porsche Macan GTS
  2. #222
    Time Bandit Jens's Avatar
    Aug 2003
    vahmont
    Raj, my brain was recalling this photo and caption that I read some years ago (Long's book). I mistook what it meant as THE homologation car rather than the prototype. My bad.
    Sorry for the hijack Gib.
    RGruppe #183
  3. #223
    Here are some pics from the day that show variations in flares. The yellow/black accents appears to be one of the early 'ST' versions (9110301558). Also, from LeMans 1970, #43 & #41 with wide-flared privateer STs (one with reverse mounted tie-downs). A rally version appears to be a SWB car with large flares but running with narrow tires in the snow. Lots of innovation on early 911s by privateers focused on winning. So even though that factory homologation version had narrow flares, privateers and presumably factory massaged offerings used the wider flares allowed under new rules. It was an exciting time for the 'little guy' with a passion to compete, and the 911 was the near-perfect base car to begin the chase.
    Gib Bosworth
    EarlySReg 434
    R Gruppe 17
  4. #224
    Jul 2006
    Corvallis, OR
    Man, ST's are so cool!
    72S, 72T now ST
  5. #225
    More "privateer" ST flares.
    These varieties were built by folks we all know over the past ten years.
    Randy Wells
    www.randywells.com/blog
    www.hotrodfilms.com
    Early S Registry #187
  6. #226
    Is this a well known (in the Porsche community) shop doing the metal work?
  7. #227
    Randy, thanks for posting those pics of more recent 'privateers STs'. While most were not intended to win on the track (exception: Plavan's and yours for autox), they are all inspired by the alluring shape created with extended flares. They also have improved handling from wider wheels, stiffer suspensions, and significantly improved engines. Maybe there needs to be an 'ST Gruppe'.
    Here are more flares from the day (except Brumos at RRIV)....'viva la flare'
    Gib Bosworth
    EarlySReg 434
    R Gruppe 17
  8. #228
    Here is a shot of the dual oil cooler short lines , with hose connections done by Brad Davis (pic taken on his bench). Brad can crimp barrels and provide barbed connectors, male/female connections in 30 mm and smaller sizes, plus hoses in various colors and types. brad@nextmill.net
    I measured the necessary hose lengths and provided them to Brad. These short lines are the final step in the process for a poor man's way of connecting oil coolers to Elephant Racing (or your own) cross over lines for an ST dual oil cooler system. The short line is for connecting the return hard line from the cooler system (passenger side) to the oil tank.
    Gib Bosworth
    EarlySReg 434
    R Gruppe 17
  9. #229
    Gib:
    Lots of good work evident in that image, a lot more than meets the eye.
    Great looking set of lines. Hats off to you and Brad.
    Thanks for all the updates.
    TC
    Early 911S Registry
    Looking for engine 960 168
    Looking for gear box 103 165
  10. #230
    Aug 2003
    vahmont
    Looks done right Gib. Through and through one hell of a nice build.
    RGruppe #183
  1. Light Yellow 73.5 T Targa - $26,000
    By res0ca5d in forum For Sale/Wanted: Early 911 Cars, 1965 - 1973
    Last Post: 05-29-2011, 08:01 AM
  2. SF Bay Area - Any Light Yellow (117) cars?
    By Ted_S in forum General Info
    Last Post: 07-01-2010, 09:37 PM
  3. Signal yellow with light yellow undercoat
    By Mark Wilson in forum General Info
    Last Post: 03-11-2009, 11:16 AM
  4. 1973 Light Yellow 911E
    By aknatar in forum For Sale/Wanted: Early 911 Cars, 1965 - 1973
    Last Post: 10-25-2006, 09:43 AM
  5. Light Yellow cars..
    By YTNUKLR in forum General Info
    Last Post: 08-08-2004, 01:35 AM
