Page 74 of 81 FirstFirst ... 24647273747576 ... LastLast
Results 731 to 740 of 809
Thread: Light Yellow ST in Progress
  1. #731
    Very nice engine, just perfect !
    #rennfrog
  2. #732
    Thanks, guys....
    More pics...center lube cams plus spray bar lube...just to be sure. MFI pump brace coming from TRE.
    Gib Bosworth
    EarlySReg 434
    R Gruppe 17
  3. #733
    Senior Member NickP's Avatar
    Mar 2006
    Solana Beach, CA
    Gib, I’m curious about the RSR oil filter. Why is this used in place of the standard oil cooler? I assume your car (and others using the RSR filter) have front mounted oil coolers. And, don’t 993’s have a similar filter set up instead of a cooler? Thx. Nick
    Nick Psyllos
    S Reg & R Gruppe
    1973 Euro 911S
    1972 911T to ST
  4. #734
    Nick
    2.5 ST’s had twin front oil coolers so the engine cooler not needed
    and the oil filter using paper discs was used instead.
    I have had issues with mine it leaked from the mag body and the replacement was cracked but EB Racing have been great in replacing both times with no hassles only problem is engine out every time to replace it��
    Engine will be epic Gib.
    Clyde Boyer
    Early S Registry Member #294
    TYP 901 Register Inc #6
  5. #735
    Atlanta, GA
    Gib, as always your engine is going to be amazing. Regarding the oil cooler question, my 2.8 uses the 993 small canister setup in lieu of the cooler and it works well. Only issue is filter changes are a little tidious due to tight space but no biggie.
    Mark Erbesfield
    1973 911S #9113301282
    1957 356A #58648
    1982 Toyota Land Cruiser FJ40
    1977 Toyota Land Cruiser FJ40
    1979 MB 450SL "Dad's old car"
    2019 Cayenne "Wife's car"
  6. #736
    Atlanta, GA
    Quote Originally Posted by letsrollbabe View Post
    I'm still riding high from that hill climb with JB....can't get that roaring engine out of my head, and those Gs...in the little beast. It's got my head somewhat disoriented....so much so that I had a dream last night....I was at LeMans....
    These pics are FREAKING AWESOME! That must have been so much fun.
    Mark Erbesfield
    1957 356A #58648
  7. #737
    I was advised by Gordon Ledbetter last week that the rear engine oil filter was also used as an oil pressure control device for the early aluminum race engines which did not have pressure relief valves in the case (even though the passages were in the casting but not opened). He has restored a 911R which used this type of filter/pressure control setup. The pressure was adjusted using the screw in the bung as seen in the pic attached.
    Gib Bosworth
    EarlySReg 434
    R Gruppe 17
  8. #738
    Mar 2006
    Solana Beach, CA
    Quote Originally Posted by BOYER73S View Post
    Nick
    Thanks Clyde, I see you also used a similar filter to Gib. I didn’t know the 2.5 ST used this set up. On my car I kept the oil cooler, plus the twin front coolers. No wonder my car never gets above 180 F!
    Nick Psyllos
    S Reg & R Gruppe
    1973 Euro 911S
    1972 911T to ST
  9. #739
    Quote Originally Posted by NickP View Post
    I bloody hope they did Nick for all the money it has cost and frustration the filter has caused.
    I think I did my research pretty well but would be ironic if I was wrong
    I think I remember seeing it on the Olive tart too
    Clyde Boyer
  10. #740
    Mar 2006
    Solana Beach, CA
    Clyde- I’m sure your research is spot on and I’m sure you’ll get the issue solved. I’ve got some changes/upgrades in the works for my engine. I’d better start reviewing the ST threads again....
    Nick Psyllos
    S Reg & R Gruppe
    1973 Euro 911S
    1972 911T to ST
  1. Light Yellow 73.5 T Targa - $26,000
    By res0ca5d in forum For Sale/Wanted: Early 911 Cars, 1965 - 1973
    Last Post: 05-29-2011, 08:01 AM
  2. SF Bay Area - Any Light Yellow (117) cars?
    By Ted_S in forum General Info
    Last Post: 07-01-2010, 09:37 PM
  3. Signal yellow with light yellow undercoat
    By Mark Wilson in forum General Info
    Last Post: 03-11-2009, 11:16 AM
  4. 1973 Light Yellow 911E
    By aknatar in forum For Sale/Wanted: Early 911 Cars, 1965 - 1973
    Last Post: 10-25-2006, 09:43 AM
  5. Light Yellow cars..
    By YTNUKLR in forum General Info
    Last Post: 08-08-2004, 01:35 AM
