Page 18 of 43 FirstFirst ... 8161718192028 ... LastLast
Results 171 to 180 of 429
  1. #171
    Aug 2010
    Front Boxster calipers to be mounted on early LWB Koni S struts next winter along with aluminum cross bar and LWB a-arms. Or maybe use the adapters for the SWB suspension. The picture of the 3 front brake pads are, M, SC, and Boxster. The Boxster hardware will be changed from clear (silver) and black to yellow (gold) to match the existing hardware on the car.
    The gold caliper is a early 914 front ATE caliper (42 mm pistons) converted to a SWB rear caliper. This has never been done on a SWB car before. This will retain a 1.6 front to rear bias.
    I try as much as possible to find never been done before solutions. It's a challenge but it's fun.
  2. #172
    Aug 2010
    A triple looper. I'm making one for each side.
    Working on a second one. The Elephant under hood crossover tubes are in.
    The finished coolers connections will be trimmed to connect to the whole system like the 73RS coolers. See picture.
  3. #173
    Aug 2010
    October was a fun month. The car was featured at a PCA event at a McClaren dealership and the following week at Ed Carroll Porsche for the debut of the 992. Both were well attended. Both sets of pictures were taken early on before the crowds. In the case of Ed Carroll it was a hour or so before the event.
  4. #174
    Aug 2010
    Ready for winter install.
    See #171
  5. #175
    May 2014
    South East USA
    if that's your orange car, could you share some detail photos of that front spliter?
    how to mount? material, etc?
    scott
  6. #176
    Aug 2010
    I made patterns then had them laser cut. I started with outside only then added a middle piece. I prefer 3 piece as I can replace pieces with different designs. 25 mph cross wind at 100 mph is totally planted.
    The unpainted car is another POLO car I'm building for a friend. That's a steel bumper with oil cooler vents. Both spliters are aluminum. Mine is currently just aluminum plate. The other and mine in the future will be hand pounded aluminum.
  7. #177
    Aug 2010
    Fall 2019 issue
  8. #178
    Aug 2010
    I started one of maybe a dozen over the winter projects on my car. Christmas to New Year is my time. I'll be back on the 911E Thursday. I'm installing a IAC valve. (idle air control). Over 9500 feet the 4 50mm throttle bodies can't get enough vacuum to suck enough air in at idle. This valve will be tied to the ECU to supplement additional air via silicone vacuum lines to each throttle body. This is the first rough fit.
  9. #179
    Senior Member nvr2mny's Avatar
    Mar 2012
    Kansas City
    Nice, clean install. Glad to see you getting quality time with #1!
    Reg#2218
  10. #180
    Aug 2010
    Thanks Doug. Almost ready. Still need tubing and a connection to the ecu.
  3. Polo Engine Dyno Results
  4. What is a POLO engine?
