Hi Scott, Great advice and thanks.
Starting with your question about CR, I understand the free HP argument to go with an S comp. set up but I guess I just figured that with a higher CR I would be moving the powerband up the rpm range and getting away from the one trait that the E engines trump the S. Okay, there are more variables including valve size and cam lift/duration. Maybe comp. has less to do with the difference between power and rpm than I first thought? Stupid now that I think about wanting an S cam, valve train as these changes probably have more effect on moving the power up the rpm range than does a simple lift to CR.
Increasing displacement only via increasing bore has the effect of decreasing compression (all else being equal) which can be brought back up by changing piston height/dome (?wording) but I wondered just how much could be regained by installing larger domed pistons without worrying about the piston coming into contact with the valves. I thought I should still be safe if I kept CR as close to the original E set up of 9.1 and maybe I shouldn’t push it higher. But then again as the head of an E is the same as the S in terms of cc size and the S has a higher lift cam with valves that are slightly larger, I need not worry about this. [Wondering out loud] If increased CR is simply just free HP, why don’t more guys who rebuild their 2.4S and 2.7RS spec engines increase their comp from 8.5 to 9.8 – the threshold deemed okay for 91 pump gas and a single spark plug? If a stock RS engine gets 210hp with 8.5:1 comp wouldn’t a bump to 9.8:1 give them much more? I imagine some people do go this route but I’ve rarely read about it. If you want 240-250HP it seems most just go with something north of 3 litres to get the desired result.
At first my motivation with this upgrade was to find about 20-25hp over a stock 2.2E. Going the SS method I get to maintain the engine’s willingness to spin up more quickly than later long strokers. I like the idea of something between an E and an S engine. I’ve heard about solex cams which have lift/durations between E & S. This sounded promising but I have read that these are only available with a carb setup.
After thinking it over, maybe maintaining the stock E cam and valve train, boring it out to 89-90mm and bumping the CR to something closer to an S 9.8:1 is the way to go… would a set up like this work? What would be wrong with this?
Lastly, the case… I’ll look into a 7R. Am I just asking for trouble going for more power while keeping a stock 1 or 3R?
I know I’ve raised a whole bunch more questions. Feel free to ignore my ramblings as this could go on forever. Thanks again Scott for your insights and input.
