Page 1 of 3 123 LastLast
Results 1 to 10 of 21
Thread: Common oil leak? MFI fuel pump drive wheel.
    I have my engine out of the car for repairs of various oil leaks and general cleanup. A question: The gear wheel that's attached to the driver side camshaft, drives the MFI fuel pump. There is a seal at the cam where it protrudes from the camshaft housing, where the wheel attaches. It looks like a miniature rear main seal. Is this frequently the cause of an oil leak? Mine's not leaking now but now would be the time to replace it, while the motor is out. Unfortunately it's not like the RMS, where it's right there and easy to get to - it's kind of down in there, hard to get to. Because it's so narrow, I can't see how to "grab" it to get it out. Then, re-installing would be a bit of a challenge as well, albeit not insurmountable.
    Anyone ever replaced this seal while the can housing was still on the car and the cam was in place?
    Senior Member beh911's Avatar
    Aug 2009
    Atlanta
    Yes, the cam tower pump drive seal is a frequent cause of leaks.
    I have also heard that sometimes replacing the seal does not fix the leak. There is some wear over time that a new seal may not address.
    Others will chime in on technique for removing it.
    1969 S Coupe #761
    Early S Registry #1624
    There is room for two of the original style seals and can be done with engine in car but you will need to remove the drive gear. New part # is 999 113 068 50
    Description; Injection Pump Drive Seal on Camshaft Carrier
    67 Normale, Old Rusty
    67 R Inspired and on a Diet
    73 T/ST Caged Beast
    RGruppe #383
    S Registry #739
    Quote Originally Posted by rick2 View Post
    So you're saying just tap a new one in over the existing old one?
    A mechanic, who works on allot of MFI ,cars told me when replacing this seal use the orange or brown color seal. He claims that the black color seal is harder and does not fit as tight. During my rebuild I used a little RTV silicone when mounting into the cam housing because my previous seal showed signs of walking out. Also, grease the shaft and the lip of the seal which goes over the shaft.
    SRL After taking off the gear you will see the seal clearly and I use a curved seal tool and work the old one out from the housing starting with the cam side of the seal. I've only used the german brown seals from Porsche. You never want to install a seal "dry" so I use a small amount of the Bosch distributer lube on the inner part of the seal that touches the drive. I'm a red neck and use a deep socket that fits over the drive but still will fit inside the cam housing (26mm if memory serves) and insert seal cupped side in flat side out. Drive the seal in about 5mm past the cam housing and then I use the additional seal and repeat the process but stopping flush with the housing. These are only good for about 2 race seasons then the engines come apart anyhow.
    My humble $.05 Use what part of the directions you want. I am not politically correct so Merry Christmas!
    73 T/ST Caged Beast
    RGruppe #383
    S Registry #739
    2 race season sounds perfect considering the mostly mellow and low street mileage this motor will see! Thanks for the tip!
    I have a MFI pump out of the car and see that the seals are made of orange silicon, on all . I have a ? how do I flusch my MFI pump and whit what product ???
    thank you
    Another 911 Driver wicks's Avatar
    Aug 2015
    West Hollywood, CA
    Bumping this thread to see if anyone knows of a newer technique to fix this? Saw a couple mentions of a cover that holds the seal better or something but searching not turning up any results on that.
    Is it still two OEM seals, (brown?) placed in succession on the cam?
    Original 911s 1973 motor, this is the only leak.
    1973 911s / 1994 964 Turbo / 1997 993c2
    Senior Member 2.5MFI's Avatar
    Sep 2006
    Bend, Oregon
    I have had excellent results using the KOCO Vitron seal 35 x 45 x 7 mounted in a alum cover plate that bolts up to the cam housing.
    Name:  MFI Cam Drive Seal Kit.jpg
    Mark Jung
    MFI Werks
    Early 911S Registry #972
    Carrera T w/LWB, MT, RWS, PCCB
    72 T 66 x 100 MFI Twin Plug Coupe
    R Gruppe #686
  1. MFI Fuel Pump Leak Help
    By 73S in forum Technical Info
    Last Post: 01-03-2022, 02:03 PM
  2. MFI fuel leak, 69S
    By NV Stig in forum Technical Info
    Last Post: 05-03-2013, 09:09 PM
  3. Fuel filter leak
    By FL-Frank in forum Technical Info
    Last Post: 04-13-2013, 02:47 PM
  4. FS: New MFI Pump Drive Gear & MFI Fuel Console
    Last Post: 01-31-2013, 11:02 AM
  5. 73 911t fuel leak
    By muncokiho in forum Technical Info
    Last Post: 11-30-2012, 06:14 AM
