Check out this car - the interior is something else!
http://www.cars.com/go/search/detail...ngId=100579631
Alex Webster
1967 911S Sunroof - RHD
1969 911E - LHD - Historic Racecar
1975 911 Carrera 2.7 MFI - RHD - Historic Racecar
My historic racing videos - www.youtube.com/aewebster
customised in the 70's perhaps?
This one is pretty close to Sb specs if it does not have fibreglass panels. Some lights, window winders, a few instruments and it should be pretty close to logbookable.
http://www.ebay.com.au/itm/230864910...84.m1423.l2649
Rob
Similar car and not as much to do.
http://bit.ly/R1k8OB
Porsche : 911 2 Litre 1966 Porsche 2 Litre ALL METAL Race Car Roll Cage Sparco Seats SCCA Carbon Fiber
Alex Webster
Fortune favours the brave:
http://cgi.ebay.com/ebaymotors/1966-...item2ec280ca91
Cheers, Ryan
Founder and chief centre cap remover at : ZOLLHAUS / Design driven custom PORSCHE : https://zoll.haus
more keep appearing for those that are prepared to get a LHD car!
http://www.thesamba.com/vw/classifie...php?id=1373218
Alex Webster
Would it be possible to run 12.5:1 compression on a single plug motor even with race fuel as the ad on the samba claims ?
Rob
Rob,
I think the quick 2.7's are running those levels.
Also, 12.5:1 pistons doesn't necessarily mean 12.5:1 compression. Heads and cylinder spacing affect actual comp ratios. From memory, high overlap cams can also reduce effective/dynamic comp ratios too.
Cheers, Ryan
Need the opinion of a mechanic to be 100% sure what could be achieved. At that higher compression though it would not be pump fuel here in Australia.
I'll hand the answer over to more qualified people!
Alex Webster
