Page 28 of 33 FirstFirst ... 182627282930 ... LastLast
Results 271 to 280 of 326
Thread: Another 72 ST build
  1. #271
    Darren that engine is looking very usedhave a good one next week.
    In period the mag lids and consoles used to crack fairly easy,just had a original one repaired.
  2. #272
    Gees Darren you have worn yours out before I have even run mine in��
    Clyde Boyer
    Early S Registry Member #294
    TYP 901 Register Inc #6
  3. #273
    Finally an exhaust solution for the ST to match up to the SSI.
    Danks have made a version of their header style sports muffler with flanges to mate up to SSI.
    Sadly the twin outlets are way too low so had to cut them off and get them welded in the correct spot.
    David from Classic Road and Track nailed it again. Now for ceramic coating and then good to go.
    I am off to Canada for 8 weeks otherwise this baby would be on the road in a week or so but I guess after 7 years a few more weeks is not going to matter.
    Clyde Boyer
  4. #274
    Finally it runs!!!
    Running in on the dyno, checking for oil leaks etc the to do list
    for completion is getting shorter.
    Clyde Boyer
  5. #275
    Senior Member Darren65's Avatar
    Aug 2011
    UK
    Video clip with sound or it never happened!
  6. #276
    LOL will figure out how to post a video to you tube
    Got a couple of minor oil leaks to address��
    Clyde Boyer
  7. #277
    Aug 2016
    NE Ohio
    @Boyer73RS, I"m new to this thread. Patience, perserverance and a wonderful car, congrats! We need video, can't wait for you to post a link. Bravo!
  8. #278
    Senior Member Bavaria911's Avatar
    Dec 2012
    Fort Meade, MD
    I see you tape the headlights in the last photo.
    Is the light popping out? Mine are, actually both rubber seals started to work loose and both H4s popped loose.
    I was thinking to use a alloy bracket to hold the tops in,but that requires drilling a small hole in the fender.
    Do you or anyone know a better way?
    The small tab in the headlight bucket doesn’t seem to be enough there for the light ring to stay in place.
    Scott
  9. #279
    You may have the dreaded thick headlight seals.
    58 speedster
    66 912
    67S
    73S
    97 VW eurovan
    1132 honda snowblower
    member Jackson Hole Ski Club
  10. #280
    Here you go Darren ete el finally on the road for the first time today, what a journey.
    Had it's first paint detail ever last week and added some clear film in the vulnerable areas.
    I am biased but it looks sensational right now.
    Runs very strong too, although didn't drive too far or too hard (tacho wasn't working) so looking forward to ironing out a couple of small bugs
    and some more longer drives next week.
    I would say it felt the quickest pre 1974 911 I have driven with the exception of Jeff Smith's 1973 red rocket, which has no peer.
    You tube video link if your interested.
    https://youtu.be/p4R-fx3Dg_0
    Clyde Boyer
  1. If you build it, they will come
    By sithot in forum Technical Info
    Last Post: 07-01-2013, 11:30 AM
  2. 2 be or not 2 be. Build as a 2.0 or 2.2
    By beetle08 in forum General Info
    Last Post: 12-12-2012, 12:41 PM
  3. Build your own RSR
    By PJenkins in forum For Sale: 911 Parts
    Last Post: 04-02-2008, 10:08 PM
  4. Help with MFI re-build
    By denson in forum General Info
    Last Post: 10-04-2007, 07:34 AM
  5. Hot Rod Build
    By Max (SD) in forum General Info
    Last Post: 02-08-2007, 08:43 PM
