Page 2 of 9 FirstFirst 1234 ... LastLast
Results 11 to 20 of 82
Thread: 2.5L Twin Plug Rebuild Options
  1. #11
    Senior Member CaryPhotography's Avatar
    Mar 2012
    Thousand Oaks
    Quote Originally Posted by Flieger View Post
    The very end of Moorpark Road, south of the 101. My Dad and I are taking the 911 out for a drive tomorrow afternoon if you would be around then.
    Sounds great, I'll PM you my info.
  2. #12
    Senior Member CamBiscuit's Avatar
    May 2006
    Adelaide, Australia
    If you are mechanically minded then why not strip it down to see what you have? Check everything for spec and then add up what costs you will have to put it back together.
    Then make a decision from there....A 2.5 would be a much more fun engine than a 3.0 even if you have to de-tune it a little to run on pump gas.
    Looking for engine # 6208151
    '74 RS 3.0 Replica
    '70 911E Bahia Red (SOLD)
    '71 911 S/T Replica 2.3 Twin plug BEAST (SOLD)
    Australian TYP 901 Register #78
    Early S Registry # 1076
  3. #13
    Apr 2008
    Virginia's Blue Ridge
    Quote Originally Posted by CaryPhotography View Post
    My father is the original owner
    OKAY! Minor detail you left off the table! With that in mind, forget selling the engine and get on with it. Best of luck, should be a blast.
  4. #14
    If it were mine I would be unable to restrain myself from trying to fire it up. Search threads about starting an engine that has been sitting. Cheers! Steve
  5. #15
    With a story like that, you must get the 2.5 short stroke, twin plug, high compression, MFI motor running in that car (but with streetable compression ratio).
  6. #16
    Mar 2012
    Thousand Oaks
    Quote Originally Posted by Cam Arnott View Post
    That thought has crossed my mind a few times especially if word gets back that the engine is in decent shape. If it's decent then I would put new rings on the pistons, fresh main bearings, seal kit, and etc to get it running again. I have a feeling it won't be that simple but fingers are crossed.
    Does anyone know were I can get some 411 on the 2.5 engines? I'd like to read up as to what their all about. From what I keep hearing they're quite unique.
  7. #17
    old softie67S
    Feb 2007
    Sanibel Fl
    Quote Originally Posted by chiroracer View Post
    Agree 1+. A 13:1 won't work on the street, but hearing it run will tell you a lot about what you want to do, or what you have to sell. What Is it your intention to keep the wide body big tail look or something more narrow bodyish?
    Tom
    67S soft rear window
    60 356 Cab
    70 914-6 3.2 short stroke twin plug
    05 Audi S4 Cabrio (commuter)
    05 Audi Alroad (family driver)
    Aprilia SR 50R (Sanibel scoot)
  8. #18
    Mar 2012
    Thousand Oaks
    Quote Originally Posted by tomkirkcis View Post
    I was told that the motor was de-tuned for street. As to what was de-tuned I don't know.
    I'm keeping the body the way it is. If I can change anything it will be RSR rear brake lights and lexan rear windows.
  9. #19
    Mar 2012
    Thousand Oaks
    Any suggestions on tires/wheels? The rear is a 285/40 15" and I don't really feel like running that size of tire/wheel. I was thinking about going to a 17's (17x8 F, 17x10 R) or 18's (18x8F, 18x10R). That way I can run a 275/35 17 or 18 in the rear.
  10. #20
    Do you mean R lights? The RSR used normal 911 lights.
  1. Twin plug cap
    By Andy 74 in forum Technical Info
    Last Post: 02-28-2013, 07:37 AM
  2. Twin plug with 1 or 2 MSD box ?
    By RS-GT in forum Technical Info
    Last Post: 06-12-2010, 05:42 AM
  3. Spark plug wire options
    By Cornpanzer in forum General Info
    Last Post: 03-26-2010, 05:00 PM
  4. Replies: 7
    Last Post: 02-15-2007, 09:31 PM
  5. 2.0 Engine rebuild options
    By zmayne in forum Technical Info
    Last Post: 06-15-2004, 04:15 PM
