Results 1 to 10 of 14
Thread: 904 gas cap
    Jan 2003
    UK
    904 gas cap
    I'm looking for this type of gas cap as used on many 904's - anybody know the origins (what other vehicle may have used it) or have a source for one ?
    I'm sure that I could probably get one from Warren Eads at Spyder Sports but any other suggestions ?
    Andy
    Early 911S Reg #753
    R Gruppe #105
    Senior Member 911_2.2T's Avatar
    Jan 2007
    Netherlands
    Andy,
    What is the size of this cap?
    Looks like the material is plain steel?
    Do you have deteailed pictures of it, front back and side?
    2.4T 1972 Targa - Tangerine German Delivery Ölklappe
    2.4T 1973 Coupe - Golden Green 911ST with 2.8 MFI TwinPlug
    1.7 1970 914-4 - Hell Elfenbein Weiss to be Sonauto GT with a Six
    Looking for engine #6522576
    Rgruppe #674
    Jan 2003
    UK
    Sorry Alex, I don't have any pictures of the underside.
    It's steel & I would guess that the overall diameter is 110mm since you also see 904's fitted with 110mm finned Blau caps (as used on 911R/ST/RSR models).
    I would think that it was also made by Blau but this style/size is not listed on their website.
    My thoughts were that it might have originated from Mercedes/Hanomag trucks but have had no luck in tracking one down so far.
    Andy
    Early 911S Reg #753
    R Gruppe #105
    Hi Andy,
    Here are a couple more pictures to reference. I think Andy Elsener made up a few of these a while back. Might give him a call or email (Andy at AndyElsener.com) his website has phone and address details..
    Brad Davis
    RGruppe #691
    Early 911S #1547
    The size is 110mm on the cap and I would say that it is steel with a hollow fin.. With the knurled edge I would say 99% that it is Blau. A few more shots..
    Brad Davis
    RGruppe #691
    Early 911S #1547
    Jan 2003
    UK
    Thanks for the heads up Brad - I'll contact andy.
    Andy
    Early 911S Reg #753
    R Gruppe #105
    Andy is this the one? (356 up to T5 but with a wing welded to it).
    RIchard
    Jan 2003
    UK
    Hi Richard - yes, I have one of those (new) which I planned to use as a base with a fabricated (hollow) 'fin'/handle if I'm not able to find a complete one.
    I have seen quite a few of the 'originals' on 904's & most look exactly the same as each other - more like an 'off the shelf' item rather than individually fabricated.
    Andy
    Early 911S Reg #753
    R Gruppe #105
    May 2012
    Tampa
    Andy, I don't have those, but I make these
    T.C.
    The Netherlands
    Gas cap
    Not the same but 110 mm as well.
    Rgds, Cees
