Results 1 to 10 of 41
Thread: Bonomelli's LOST twin cam engine
    Sep 2008
    Monza, Italy
    3 valve, twin cam, twin spark, flat pistons, special parts, 1300 (180cv), 2000 (270cv)and 2700 (330 cv) cc.
    i'm already shocked.
    for now look at the pictures.
    source:
    more infos in the near future.... if the aliens don't kidnap me...
    Registry Member #1414
    NOSGRUPPE
    Senior Member Orbit's Avatar
    Jupiter , Florida
    Amazing pictures - this person was in search of power. I used Google search to find out more about Bonomelli, I believe the man is Ennio Bonomelli? Is there anywhere we could read more about Bonomelli ? It seems he was quite involved with Porsche Racing. Racingsportscars.com only has a little information about him but he was in some big races with some great cars , 1974 at Monza in a 3.0 RSR with Michael Keyser (USA) . Interesting that in the RSC description the engine is listed a Porsche/Bonomelli F6 2v SOHC. I am sure that Bonomelli has many stories to be told.
    Wonder if it was used in this?...
    http://www.invaluable.com/auction-lo...1-c-9bzx7g6q3r
    Tapiro
    This Porsche show car used a Bonomelli-tuned 2.4 liter engine
    [/QUOTE]
    the 3-valve engine is based on a porsche 911 2.0 engine
    cylinders 6
    induction valves 12
    exhaust valves 6
    distributor marelli - twin plug
    cams 4 (4 bearings)
    bore 80 mm
    stroke 66 mm
    max rpm 9.000
    slide valve set up carrera 10 (910)
    intake stacks 917
    mfi pump: Carrera 10 - bosch
    spark plugs: 2 x10 mm/cyl
    distributor: Carrera 10 - marelli
    wiring loom: Marelli
    cooling fan set up: Carrera 10
    exhaust: 3in1+ 3in1 headers with carrera 10 megaphones
    oil-pump: Carrera 10
    flywheel: Custom steel
    induction ports: 38 mm
    induction valves: 2 x 33 mm
    exhaust port: 42,5 mm
    exhaust valves: 1 x 39,5 mm
    valve springs: Double
    c/r: 12,5 : 1
    piston rings: Top 1,5mm l
    second 1,5mm
    oil control 3mm
    con rods: Carrera 10 titanium
    crankshaft: Carrera 10
    engine case: Carrera10
    cam housings: Cast alusil
    valve covers 4 magnesium with integrated oiling channels
    a second version of the engine was planned with gear-driven cams, a shorter stroke with a special crank and a 83mm bore.
    They paid particular attention to the cam oiling and the oil cooling capacity of the engine was nearly doubled.
    Sep 2008
    Monza, Italy
    flieger
    compliment to have found that pelican post.
    i confirm to you that's the same engine.
    i know the italian 70 years old man, Gottifredi. he was the chief designer of ennio bonomelli.
    .... more info to come...
    NOSGRUPPE
  1. Replies: 23
    Last Post: 08-30-2012, 06:01 PM
  2. 2.3 Twin Plug Engine is Done
    By CamBiscuit in forum General Info
    Last Post: 06-09-2010, 08:38 PM
  3. FS: Twin Plug ST Engine Rebuilt
    By mrbmw2002 in forum For Sale: 911 Parts
    Last Post: 03-31-2010, 09:16 PM
  4. Twin rear engine grills on MY 64 ?
    By 911T1971 in forum General Info
    Last Post: 07-10-2009, 01:39 PM
  5. 3.5 litre twin plug engine
    By Howard Lazarus in forum General Info
    Last Post: 08-17-2005, 09:31 AM
