Page 2 of 5 FirstFirst 1234 ... LastLast
Results 11 to 20 of 41
Thread: 2.4E to 2.7RS spec
  1. #11
    Senior Member HughH's Avatar
    Dec 2004
    Melbourne Australia
    Quote Originally Posted by silver911 View Post
    The case was machined to accept the 2.7 P+Cs.. along with mods for greater oil flow (I think..)
    Yes the case needs machining so it is not reversible back to 2.4 and I also had oil flow modifications "while we were there" including a turbo oil pump although i understand the trick upgrade in this area now is a GT3 oil pump
    Hugh Hodges
    73 911E
    Melbourne Australia
    Foundation Member #005
    Early S Registry #776
  2. #12
    Aug 2009
    Germany HG
    Quote Originally Posted by HughH View Post
    I wouldn't put a GT3 oil pump in as this would mean way to much oil pressure, especially for the Mag-engines. Put in a 964 (or the very similar 930) pump and you are done.
    Cheers,
    Christian
    RGruppe #649
    Early911S #1788
  3. #13
    Jan 2003
    London
    ....it is not reversible back to 2.4 a.....
    Even if you could go back.... would you?
    Really???
    I don't think so....
  4. #14
    I have the 930 pump in mine also, I'm sure one of the newer pumps would be better. The biggest difference for me from the 2.4S spec was the phenomenal torque. I stayed with my S ratios so it's quite quick acceleration. I wonder how much more torque the E would get, you'd save on the heads and throttle bodies.
    I sure wish this 9.5 pistons had been readily available when I did my conversion (1982). It sure didn't affect the durability or reliability of the motor. I would never go back.
  5. #15
    Jul 2009
    Hamilton, New Zealand
    So I'm guessing here but if you leave the E cams in the rev limit stays the the same?
  6. #16
    If you are upgrading to forged pistons instead of cast (which I believe were stock to the e) and went with some stiffer valve springs you could possibly go higher, but the cams would not produce much at the higher limit.
    But I'm not an engine builder please seek professional help.
  7. #17
    Jan 2003
    London
    With the 2.7 torque/power curves the 7100 limit provides a good excuse to use all it...
    However it does feel a bit breathless on the track.
    For my use of the car the additional 200 rpm would increase my familiarity with the local law enforcement cameras...
  8. #18
    If you're buying Mahle P+C's then you may as well buy the 2.8 versions. I have them in my rally car and its a fantastic motor.
    Cost difference was negligible when I was buying (via EBS).
    I also have the GT3 oil pump and no issues with excessive pressures.
    Cheers, Ryan
    Founder and chief centre cap remover at : ZOLLHAUS / Design driven custom PORSCHE : https://zoll.haus
  9. #19
    I thought the 2.8's used completely different heads, and if we used them with S heads the compression ratio would be above 10.5, then you need twin ignition. I think 2.8 really pushes the mag block just a bit to far.
  10. #20
    Senior Member Christian Guthrie's Avatar
    Jun 2011
    Arizona
    At what point do you need to do external oil coolers? I've heard 2.4 is about the max before going to the front coolers. Any truth to this?
  1. Italian Spec vs US Spec 911S?
    By 73ess in forum General Info
    Last Post: 01-14-2014, 03:10 AM
  2. Need spec details of 1968 Euro (ROW) S vs. US-spec 1968 S
    By Peter Linsky in forum General Info
    Last Post: 10-20-2011, 03:23 PM
  3. 28.5 MPG with a 2.7 RS Spec MFI?
    Last Post: 12-25-2008, 07:01 PM
  4. MFI spec.
    Last Post: 04-10-2008, 10:42 PM
  5. F/S 73 911 2.7RS Spec.
    By Bobby Smith in forum For Sale/Wanted: Early 911 Cars, 1965 - 1973
    Last Post: 06-30-2006, 10:48 AM
