I am considering replacing the front lights wiring harness (911.612.003.00) in my 70t as some of the wires have been trimmed and it does not sit neatly above the fuse boxes as a result. May also take the opportunity to customize slightly to neaten up the relay install for running higher wattage globes.
Does anybody know if the 6 pin connector used to connect this harness with the headlight harnesses is Porsche specific or some other standard, what it might be called and where I might be purchased?
