Page 2 of 12 FirstFirst 1234 ... LastLast
Results 11 to 20 of 114
Thread: Barnfind 911S chassis 310001S in South Africa
  1. #11
    Mar 2012
    South Africa
    I bought original bumpers and boot lid for my car so far.
    Name:  correct parts.jpg
  2. #12
    Good luck Greg, I've tried Tim Abbott.
    My only other lead was a previous owner in 2000,
    A mr Marc Wade, but cannot track him down..
    I have his address in Fourways, sandton but cannot find
    Any phone number for him...
    Your car look pretty solid , lee
  3. #13
    Have you got any pics of the interior?
    Cheers lee
  4. #14
    Senior Member platas's Avatar
    Jun 2005
    Spain/Houston
    What a true barm find Congrats
    San
    53 Pre A, 65 356
    70 914/6 GT
    65 912, 67 911
    71 911 Targa,72 E Tara, 73 911 Targa
    70 911 S,71 911 S,70 911 T,
    71 911 T, 72 911 E ,73 911 T
    74 911 Coupe
    74 911 Targa
    1972 RennSport Bus
    Early Reg # 771
  5. #15
    Restoration newbie.
    Jun 2007
    San Francisco
    Quote Originally Posted by gregary
    Engine No. 981712
    I would ask for a double check on this engine number, it's not in the accepted range of available engine (nor is your chassis number but you have stampings to prove that is correct)
    All other 67S engines start 96.
    It could be a test engine or it could be a typo. The reason I feel it could be a typo is because April 67 production cars had engine numbers right around 961700. They were not produced in strict order but they were in rough order.
    andy
    67S in pieces
    EarlyS: 1358
    [SIGPIC][/SIGPIC]
  6. #16
    Aug 2012
    NL, 300km from Nürburgring
    Congratulations on the barnfind and good luck with the massive project!! Something about the side pics keeps bugging me apart from the butchered wheel arch. Isn't that wheel sitting a bit far back? Did some funny character actually try to convert the car to LWB or is it just the angle of the photo?
    Cheers, Steve
  7. #17
    Senior Member HughH's Avatar
    Dec 2004
    Melbourne Australia
    Great find
    I agree that the engine number may be a typo. But stranger things have happened. In my experience the factory also had a number of engine series numbers and chassis series numbers that are not "in the books".
    However with such a high number "1712" it is unlikely to be a special series. For example the books say the range for the "96" "s" series engines (901/02) in 1967 ended with serial number "1178"; ie the last one was 961178.
    BUT
    if you look at the kardex details of "sports purpose" cars from that time they have much higher numbers. For example a 1967 S rallye car 307671S had engine 961778 (which was also shown in 308101S at one stage); 308291S had engine 961989; 308505S had engine 962163 etc
    so it might be 961712 instead of 981712, ..............an easy mistake with poor writing
    are you sure it does not ALSO have another "production" serial number for the chassis. Some Versuch cars seem to have both a internal number like your 310xxx and a production number (usually very low in the series - ie under 10) as well
    best of luck with your research
    Hugh Hodges
    73 911E
    Melbourne Australia
    Foundation Member #005
    Early S Registry #776
  8. #18
    Restoration newbie.
    Jun 2007
    San Francisco
    Quote Originally Posted by HughH View Post
    Hugh, do you have the source for this? We have heaps of cars in the registry database with numbers well into the 2s, i.e. 962XXX engines.
    Surely not all of these are sport purpose cars. Perhaps it's the 66 calendar year which ended at engine number 961178.
    andy
    67S in pieces
    EarlyS: 1358
    [SIGPIC][/SIGPIC]
  9. #19
    Dec 2004
    Melbourne Australia
    andy
    I think the some of the "main" source books perhaps copied each other on some matters - such as Morgan - and one had a typo at one stage. Morgan has this range, as do a number of others however as many have noted there are errors in the detail of Morgan's book
    The best source of these that i use is Boschen and Barth 1978 edition that says the 1966 911S engine range went to 962178 not 961178 (for chassis numbers 305101S to 308523S).
    However they show it in 2 separate lines: 960001 - 961144 and then 961145 - 962178.
    In other reference books i have like Morgan and the online http://www.elferhelfer.com. they show the 1967S with the same chassis number range but the lower engine number range to 961178. Maybe they mis-copied the numbers from Boschen??
    The higher range fits in with the numbers i have seen on kardexes etc and i think is correct BUT I was trying (maybe not clearly enough) to make the point that just because an "accepted reference book" does not have a number or range listed it doesn't mean it does not exist.
    interestingly the Boschen and Barth book calls the "1967S" chassis number range from 1180001 onwards - ie when it was written were they were using the year MADE not the model year as reference?. Therefore i suspect that the split range for the "1966S" may be the calendar 66 and calendar 67 cars???
    the advantage of using an early edition book is that it was written closer to the time - the disadvantage is that it misses out on new information. I think this time the advantages outweigh the disadvantages
    also the relatively recent Achiele "Porsche 911 engine history and development" also has the same breakdown as Boschen and Barth AND calls them model year 1966 cars
    also FWIIW neither book show a 98xxxx range of engines
    Hugh Hodges
    73 911E
    Melbourne Australia
  10. #20
    Oct 2008
    Burford, ON, Canada
    Quote Originally Posted by ajwans View Post
    I would ask for a double check on this engine number, it's not in the accepted range of available engine.
    All other 67S engines start 96. It could be a test engine or it could be a typo. The reason I feel it could be a typo is because April 67 production cars had engine numbers right around 961700. They were not produced in strict order but they were in rough order.
    I fully agree with the likelihood of a typo. There is no 98xxxx series, and April serial #'s would be appropriate.
    The 31xxxx, 32xxxx and 33xxxx VIN's are a little known series of prototypes from 1967 through 1969. Details are scarce. Very interesting that so many have popped up in the last year or so.
  1. Peco Motors Pretoria, South Africa
    By leedurrant73 in forum General Info
    Last Post: 06-22-2013, 02:06 AM
  2. Seat Belts found in my car- ex South Africa
    Last Post: 05-14-2013, 07:05 AM
  3. Racing in South Africa
    By ST Man in forum Drives, Tours, Gatherings, Racing and Adventures
    Last Post: 02-02-2010, 04:34 AM
  4. FS: '68 S Soft Window in South Africa
    By popowitz in forum For Sale/Wanted: Early 911 Cars, 1965 - 1973
    Last Post: 09-22-2009, 10:58 PM
  5. Cape Town South Africa
    By steven0401 in forum General Info
    Last Post: 08-20-2009, 06:30 AM
Tags for this Thread
