Page 9 of 12 FirstFirst ... 7891011 ... LastLast
Results 81 to 90 of 117
Thread: Door Seals
  1. #81
    Thanks for the additional info. I have to say my previous both '72 E and '81 SC were very quiet. My current seals on my '65 car are very odd, first they don't look very deep, they are hollow inside and have some sort of holes in them too. They are one piece however so can't be just random door seal.Name:  IMG_20191209_154423.jpg
Size:  68.1 KBName:  IMG_20191209_154410.jpg
Size:  46.7 KBName:  IMG_20191209_154325.jpg
Size:  73.2 KBName:  IMG_20191209_154342.jpg
  2. #82
    Those are later 70s-80s seals. I'm not a 901 expert but have inspected several "barn find" '65s as well as Weldon Scrogham's pristine original '65...they all had, with the exception of Weldon's, petrified solid lipped seals as discussed in earlier posts in this thread.
    Mark Smedley
    '59 VW Typ I
    '69 911T 2.7
    '86 930
    '04 GT3
    '16 Boxster GTS
  3. #83
    Interesting, I have not seen seals with this "stripy" texture and that are so "shallow" in vertical depth. On my '72 and '81 cars they were certainly smooth and looked much bigger/bulkier. The dilemma is - whether to fiddle with these ones with Sugru, buy original spec solid ones then fiddle or buy new set from Porsche and see what they are like.
  4. #84
    Quote Originally Posted by Dr_Danger View Post
    I've restored 65-66 911s from "original" stock and the seals you show with ribs are identical to the three cars I've done. I assume the holes allow air to escape when the door is closed and seal compressed. If these seals are not correct for 65-66 I'd like to know which ones are
    John Schiavone
    Connecticut
  5. #85
    Quote Originally Posted by John912 View Post
    I think at the beginning of the thread the solid type are correct (that look like a whale in the cross section). I'm more interested in performance however.
  6. #86
    I have now managed to obtain 5 versions of seals from different vendors.
    Did anyone manage to reproduce or even see what the Desk Pad from the catalogue was and where it went?
  7. #87
    A factory Service Bulletin from December 1965.
    Jon B.
    Vista, CA
  8. #88
    So they started with the hollow type! then went onto the "devil with wonky horn" then "diving man" and finally "dead whale" before coming back to hollow type for the LWB cars ...
  9. #89
    So...llli am interested in an evaluation of the 5 vendor seals.
    Please let us know analysis
    ft
    73.5 Snrf T
    71 Snrf T
    70S targa
    76 914 2.0
    82 Targa,
    85 Alfa GTV6
    60 Lancia Appia Zagato GTE
  10. #90
    Wow! The WORD! a factory bulletin. Just when you think you know...you don't! None of the early cars I had seen had those hollow seals.....either later production or replaced back in the day. cool!
    Mark Smedley
    '59 VW Typ I
    '69 911T 2.7
    '86 930
    '04 GT3
    '16 Boxster GTS
  1. Door/Window seals?
    By A.T. in forum Technical Info
    Last Post: 02-28-2014, 12:49 PM
  2. Door Seals New
    By BBausser in forum For Sale: 911 Parts
    Last Post: 08-31-2010, 01:31 PM
  3. WANTED: door handle seals for 1969 door handles
    By obrut in forum For Sale: 911 Parts
    Last Post: 05-15-2010, 06:15 PM
  4. Replacing Door seals
    By Type911 in forum Technical Info
    Last Post: 11-06-2005, 01:57 AM
  5. door seals for SWB
    By mjmoran in forum Technical Info
    Last Post: 04-21-2005, 09:15 PM
