Thread: how does the rear fog light suppose to work?
    Sep 2011
    Los Angeles California , subburbs
    hello all,
    how does a rear fog light work? lame question i know. i find no purpose for it in so cal. Does it light up when the fog lights are on ..or is it suppose to light up when the back up light are lit? i found some wires in the rear. and it matches the wiring diagram..
    thanks
    Lem
    Senior Member HughH's Avatar
    Dec 2004
    Melbourne Australia
    it is supposed to work independently of the front fog lights and may work differently in different markets due to road rules.
    Here in Australia (actually Victoria as i am not sure that the rules are even consistent across Australia) the front or rear fog lights cant be turned on without other low beam or side lights but i don't believe they are allowed to be on in conjunction with high beam. Also they must be wired so that they are turned on separately from other lights as it is illegal to use them in other than poor viability conditions.
    therefore the back one should NOT automatically light up when the rear lights are on
    The factory switch for my 73 car is a three position one - using both pull out and twist
    From memory the pullout gives front only and only if sidelight or main beam is on. The twist gives rears only and pull and twist gives both. There used to be separate laws here about the use of a rear fog light (and there may be elsewhere) that meant that they had to be able to be operated separately from each other
    given the rarity of the 3 position switches (i have been looking for one for a few years now ... hint hint) most are now used with 2 position pull switches, the first pull for fronts the second for both.
    Hugh Hodges
    73 911E
    Melbourne Australia
    Foundation Member #005
    Early S Registry #776
    Aug 2012
    France
    I could not say much. Europe treatment same as Autralia :-) (at once). Independant rear fog light - 3/2 position switch on classics.
    Xavier
    O-G 26 - Early911S 2407
    Senior Member beh911's Avatar
    Aug 2009
    Atlanta
    Hugh's recollection write up in the second post is spot on. Here is an entry I did on the rear fog in my car, including the part numbers for the 3 position switch
    http://www.early911sregistry.org/for...l=1#post561551
    1969 S Coupe #761
    Early S Registry #1624
    Thumbs up
    Great question, and great recollections and answers....... thanks guys
  1. Suppose we build....
    By TRE Cup in forum General Info
    Last Post: 05-19-2018, 04:34 PM
  2. Rear fog light
    By early911 in forum Technical Info
    Last Post: 07-07-2005, 05:07 PM
  3. Rear Fog light for RS
    By BOYER73S in forum General Info
    Last Post: 07-07-2005, 10:39 AM
  4. Rear Fog light for RS
    Last Post: 05-03-2005, 06:15 AM
  5. Does your Rear Defroster Work?
    By larry47us in forum General Info
    Last Post: 09-24-2004, 07:40 AM
