Page 21 of 30 FirstFirst ... 111920212223 ... LastLast
Results 201 to 210 of 297
Thread: A challenge? 1970S resto
  1. #201
    Senior Member timgt3's Avatar
    Oct 2010
    Gold Coast, Australia
    Thanks Tony. I still have to finish the oil lines. I mocked them up with the kidney bowl and the sill screwed in. Everything fits up nicely. I am pretty much ready to mount them up properly tomorrow, in preparation for the outer sill weld up. It pretty exciting. the rear quarter, door and front guard all look great.
    Very excited!
    Tim Pritchard
    1970 911S (resto underway) http://www.early911sregistry.org/for...ge-1970S-resto
    1976 Carrera 3.0 Group Sc Race Car
    1969 911T Group Sb Race Car (Sold to a good home)
  2. #202
    #2264 classic's Avatar
    Nov 2004
    Gold Coast.
    And so you should be, it's looking great........
    It's going to worth all the blood sweat and tears.......and it's an S
    Tony
  3. #203
    Oct 2010
    Panel Gaps
    Yesterday I secured the oil lines behind the sills and welded the modified kidney bowls to take the lines. Its one of those jobs that takes a long time as I checked against the sill and the fender joining panel about 20 times. Once the kidney bowl was on, it gave me the chance to offer the rear qtr panel up and fit the front guard to get the fender joining panel in the correct position.
    This has been the most satisfying process yet. The panel gaps are sensational, with only a slight raised area at the top of the fender against the door. I think this can be improved once everything it welded up and I can put some real pressure on the guard. The sill gap has come up really well. It needs a little more relief around the jack point and it can be welded up.
Size:  75.6 KBName:  IMG_2954.jpg
Size:  95.2 KBName:  IMG_2955.jpg
Size:  85.3 KBName:  IMG_2956.jpg
Size:  90.1 KBName:  IMG_2952.jpg
    Next up, seam seal under the outer sill and weld the outer sill and fender joining panel in place.
    Tim Pritchard
  4. #204
    Oct 2010
    Holy Cowl!
    Today was the last step of removing the poor lhd to rhd botch job on the S. I have been planning this in my mind for months and today, and having other 70 shell available has given me plenty of options for the repair patch.
    I braced the front strut area and welded in some support. Then I cut!! The whole cpwl and remains of the dash were removed in one piece. I have unpiched the cowl and the top piece of the dash as one piece to go back in. Removing this has given me amazing access to the rust, and the ability to patch the really rotten areas on the LHS.
    With the access I could get to the areas that were poorly welded and cut out more than I would have otherwise.
Size:  112.0 KBName:  IMG_0024.jpg
    I had previously cut out and prepped the inner fender piece I needed. Once san blasted E-primed and weld through primed, I could offer it up using the bonnet hinge to locate it properly. The result is so much better than the RHS repair I did earlier. I am going to go back and fix that one a little bit now!
    I then spent about two hours cutting the panel that runs from the wheel well through to the dash. This is the panel that was completely eaten away. It also attaches the inner fender and the firewall, so its pretty fricken important. This came out of the SC front cut I had. It was a bugger to get out , but being so vital it was worth the effort. Once I cleaned it up, It fitted in nicely.
    Tim Pritchard
  5. #205
    Oct 2010
    And a reminder of before and after....
Size:  133.1 KBName:  IMG_2543.jpg
    Tim Pritchard
  6. #206
    Unreal Tim, that rocker to door line looks fantastic.
    Cheers, Ryan
    Founder and chief centre cap remover at : ZOLLHAUS / Design driven custom PORSCHE : https://zoll.haus
  7. #207
    Aug 2011
    Australia
    Good work Tim.
    S Registry#2021
  8. #208
    Nov 2004
    Gold Coast.
    Gaps look perfect Tim.
    Nice job on pulling the dash.
    Tony
  9. #209
    Port Macquarie, Australia
    Great work mate.a real credit to you!
    John Forcier
    EarlyS #1987
    Restoration Saga
  10. #210
    Oct 2010
    All welded up ready for the inner wheel arch patch to go in.
Size:  113.3 KBName:  IMG_3022.jpg
    Tim Pritchard
  1. early car challenge for experts
    By hesaputz in forum General Info
    Last Post: 12-06-2017, 01:36 AM
  2. 1970S Resto Help
    By timgt3 in forum General Info
    Last Post: 02-28-2015, 12:18 PM
  3. A challenge? 1970S resto
    By timgt3 in forum Australia
    Last Post: 12-08-2012, 01:17 PM
  4. CSRG Charity Challenge
    By John Z Goriup in forum Drives, Tours, Gatherings, Racing and Adventures
    Last Post: 10-03-2011, 07:31 PM
  5. Border Challenge 2005
    By A.T. in forum General Info
    Last Post: 12-17-2004, 07:29 PM
