Page 1 of 3 123 LastLast
Results 1 to 10 of 28
Thread: Has ANYBODY replaced the windshield washer motor on the washer fluid tank?
    Apr 2011
    N.Calif., south of SF
    ....I am embarrassed to say how much time I've spent on this. So far I've-
    -used lube
    -levered the little circle trying to press it into the round hole on the washer pump
    -heated the white plastic tank and then tried pressing it into the hole
    -(above) and levered it
    -put the white tank into the freezer
    etc, etc. Thought I got it but .....
    Your experience, suggestions and methods and repair links would greatly be appreciated.
    With sore hands and grumpy disposition,
    (This is for the 73 911S)
    Haasman
    Haasman
    Registry #2489
    R Gruppe #722
    65 911 #302580
    70 914-6 #9140431874
    73 911s #9113300709
    Quote Originally Posted by Haasman View Post
    -used lube
    Haasman
    Did you have water in the tank before freezing it. This technique has worked for me.
    911 S Registry # 1054
    1970 911 E Coupe Signal Orange (#1414)
    1979 BMW 320i
    2001 Boxster S
    2003 Audi Allroad 2.7T Tiptronic
    2014 Jetta Sportwagon TDI DSG ( sold back to Volkswagen)
    2015 Allroad 2.0 TFSI
    Apr 2011
    No, do you suggest freezing water in the tank before trying to get the motor bracket on?
    Haasman
    Haasman
    Registry #2489
    R Gruppe #722
    65 911 #302580
    73 911s #9113300709
    Haasman
    Yes. Fill with water just above the round mounting protrusion. Tank will not crack or collapse while mounting the bracket.
    1979 BMW 320i
    2001 Boxster S
    Apr 2011
    I'll give it a try!
    Haasman
    Haasman
    Registry #2489
    R Gruppe #722
    65 911 #302580
    73 911s #9113300709
    Apr 2011
    Great idea. The tank may just be too old-the pump bracket wouldn't stay secured on tank so I used a dab of clear silicone on it. Now its secure.
    What do I do with the ice?
    Haasman
    Haasman
    Registry #2489
    R Gruppe #722
    65 911 #302580
    73 911s #9113300709
    Aug 2011
    New York
    I filled mine with water and froze it to mount the bracket. Was still difficult, but I could not get it on without the ice keeping it rigid.
    Unbelievable. Now that I destroyed the current bottle, I will order an oem one, fill and freeze the water and give this a whirl. This has taken on a very funny theme now.
    RGruppe member 445
    Apr 2011
    Well, keep us posted. I finally gave up and used a series of tie-wraps to hold the pump in place.
    Haasman
    Registry #2489
    R Gruppe #722
    65 911 #302580
    73 911s #9113300709
    I have done a great deal of work on my vintage cars for 20 years. No job? has frustrated me more. I needed to start to laugh after 2 hours in the garage. I greased the bottle and pump housing, took the bracket off the pump thinking maybe it would be easier that way (no), stuck a dull edged phillps head screwdriver in to push it out,,,,,,, all while I am only laughing (and using some words I have not used in quite a while)
    I am understanding the tie wrap use! Now I await a new pump and bottle and shall go with the frozen bottle aproach. If this does not work,,,,,,,,,,,,,,,,,
    RGruppe member 445
  1. WTB: Plastic Windshield washer tank as a catch can/tank
    By Bavaria911 in forum For Sale: 911 Parts
    Last Post: 05-29-2013, 06:42 AM
  2. 1965 911 Windshield Washer Fluid Pump
    By dad-ladproject in forum Technical Info
    Last Post: 05-05-2012, 04:21 PM
  3. F/S 1970 Windshield Washer Bottle with Motor
    By runsub5 in forum For Sale: 911 Parts
    Last Post: 10-31-2011, 09:17 AM
  4. Windshield Washer Fluid Tank Filler for 1965
    By Bobs 67S in forum Technical Info
    Last Post: 08-07-2010, 10:36 AM
  5. FS: 73 Windshield washer tank and pump
    Last Post: 04-19-2008, 07:59 AM
