Results 1 to 10 of 12
Thread: Can anyone comment on the ride & driving quality of Avon CR6ZZ Tires for street use?
    Port Macquarie, Australia
    You "may" also be able to find Michelin TBs in 18/60 and 15/60 (215/55 and 185/70 roughly). TBs are legal, TB15s are not.
    John Forcier
    EarlyS #1987
    Restoration Saga
    Feb 2010
    San Francisco, CA
    I have the Avons on my car (185 all around) and like the ride quality quite a bit. They are quiet and grippy in the dry. They pick up stones when driving slowly. I haven't taken them out on wet roads, but would expect them not to be very safe, fortunately my car doesn't go out in the rain
    I'd recommend the harder of the two compound options for durability.
    Not much of a technical analysis, but I haven't got any complaints.
    Kent
    E911SR & RGRUPPE
    '73 S Coupe #306
    Senior Member 210bhp's Avatar
    Feb 2004
    Scotland
    SKM
    I couldn't recommend these tyres enough. They are a particular favourite of quite a few drivers over on the DDK site in the UK. I run the exact original combination you mention on my RS and have done for eight years or more. They look period, they perform well (sticky in the dry, reasonable in the wet), they last resonably well ( about 10k kilometres for me), give a good ride and reasonably easy to get. They are expensive in these sizes and for some reason they are not rated the same between the sizes, H and N rated but this does not seem to have caused anyone any dilemmas. They have to be mounted the correct way round to avoid delamination. When I changed to a different set of wheels during Fuchs refurbishment the replacement wheels were mounted with different tyres and the difference in grip and performance was worse so I can't wait to get back to the Avons.
    Mike
    RS#1551(sold)
    67S
    Early S reg. #681
    The Netherlands
    SKM,
    After the good info we really expect a picture of your RS. As I understand your RS was originally Dutch delivery from Pon?
    Best regards,
    Cees
    Jan 2003
    NW Indiana
    Interesting, I don't see two different compounds listed on the Avon Motorsports website. Mike, do you know which compound your tires are? Thanks.
    Yes Cees, I am hoping for the same. This RSH is a real gem. I am hoping SM will add his car to this thread, seems only appropriate.
    http://www.early911sregistry.org/for...highlight=1382
    Brian
    '71T
    R Gruppe #299
    Feb 2010
    San Francisco, CA
    Quote Originally Posted by fryardds View Post
    Hmmm... when I bought mine from Roger Kraus they had listed both a hard and soft versions. They recommended the "hard". I'll try to dig out my catalogue from them and see if there is a part number listed.
    edit
    OK, here you go. This links shows what is offered for each size:
    http://rogerkrausracing.com/racetire...CR6ZZ+2012.pdf
    E911SR & RGRUPPE
    '73 S Coupe #306
    Feb 2010
    San Francisco, CA
    Here's a little bit of info I could find regarding Avon compound designation. I'm not sure if all compounds are available for the CR6ZZ
    http://www.gordonleven.com/motorspor...php?tyre=cr6zz
    It looks like this dealer offers them in A29 or A30 compounds:
    https://www.vintagetyres.com/product...es/radial/avon
    Hopefully that will help a little.
    E911SR & RGRUPPE
    '73 S Coupe #306
    Feb 2004
    Scotland
    Perhaps I wasn't clear enough. It was the speed rating I was talking about. They are different front and back.
    Mike
    RS#1551(sold)
    67S
    Early S reg. #681
    Aug 2012
    NL, 300km from Nürburgring
    Pirelli P6000 is also available in both sizes with Porsche's N2 approval code as a "modern-ish" street tire. I like CR6ZZ a lot, but they're more R-comp than street tire. It depends on your use what you prefer.
  1. Avon CR6ZZ
    By tfiv in forum Technical Info
    Last Post: 03-23-2022, 01:12 PM
  2. Tires for 69S street
    By hidesert in forum Technical Info
    Last Post: 05-27-2009, 09:32 PM
  3. avon cr6zz: Good or Bad?
    By turfclubroad in forum Technical Info
    Last Post: 10-11-2004, 04:26 PM
  4. any1 running Summitomo tires on street car?
    By joelrkaplan in forum Technical Info
    Last Post: 05-03-2004, 05:51 PM
