Thread: Size speakers in footwell map pockets?
    I have an Alpine unit to replace my Sony 80's craptastic broken deck. There are two bad speakers in the dash tha need replacing, and I wanted to get two speakers mounted in the map pockets in the footwell. Anyone tried this? Anyone know the sizes you can fit down there?
    - Brian
    1966 Mercedes 250SE Cab
    Jan 2007
    North of the GG Bridge
    On the SWB cars there is plenty of room to mount speakers in the footwells. As I recall you can get 6" in there. I mounted a 1/4" plywood backing for the actual speaker mounting. They are out of the way and work well.
    Do you mean something like that?
    Name:  altoparlanti tasche anteriori.JPG
    Instagram
    Twitter
    Jan 2007
    The idea is to mount the speaker behind the map pocket to the kick panel installed board.
    Apr 2011
    N.Calif., south of SF
    Years ago I did this with the '65. I wasn't that pleased with the bass. Of course speaker technology has certainly improved over the years-heavier & specialized magnets, cone materials etc.
    I've fascinated with these:
    UNDERCOVER Speaker Enclosures
    Custom Autosound designed and manufactured these speakers specifically for 'under seat' or horizontal 'wall' installations. 'Could be used on large 'parcel shelves' - wherever! Compact unit with one 5½" woofer and piezo tweeter in each enclosure. Under seat fit for most pre '78 cars and trucks. 120 watt capacity! If you've got the space we have the solution! Each enclosure measures 3" high X 8-1/4" wide X 11-1/4" long. Sold in pairs
    Undercover1 $119.95
    Name:  UNDERCOVER Speaker Enclosures .jpg
    Having a fairly large enclosed speaker system all under the front seats is appealing. Yes the highs would be somewhat muted but with a high-output radio head, could be a great, clean and stealth solution. The exact fit has yet to be verified.
    Haasman
    Haasman
    Registry #2489
    R Gruppe #722
    65 911 #302580
    70 914-6 #9140431874
    73 911s #9113300709
    Quote Originally Posted by 68911+1 View Post
    I like that idea - clean and hidden, like I was looking for.
    Those Undercover ones would work well under the seats of my 71 Suburban. Thanks!
    - Brian
  1. Hiding speakers...
    By Kris Clewell in forum Technical Info
    Last Post: 07-24-2014, 04:01 PM
  2. Stereo speakers
    By Rolls 912 in forum Technical Info
    Last Post: 01-30-2013, 12:30 AM
  3. 4 speakers - 71E
    By X-Faktory in forum Technical Info
    Last Post: 12-27-2007, 08:29 PM
  4. Replies: 1
    Last Post: 01-18-2003, 08:14 PM
  5. Speakers for Center Dash
    By ctpj in forum Technical Info
    Last Post: 12-05-2002, 08:50 PM
