Page 273 of 296 FirstFirst ... 173223263271272273274275283 ... LastLast
Results 2,721 to 2,730 of 2954
  1. #2721
    Not even for mine. But a genuine felt lined fat rimmed wheel.
    Edit: finished.
  2. #2722
    Mar 2013
    Surrey, UK
    Fixed my 70 wiper park problem
  3. #2723
    Machine work
  4. #2724
    Another threade . . .
    https://www.early911sregistry.org/fo...-a-drive-today
    Apr 2014
    Germany
    Installed the RennShift Performance Shifter to my 2.2 S today. Next on the to do list is swapping the original shift coupler to the precision shift coupler and then I’ll have a try on aligning everything.
    1970 911 2.2 S Coupé Bahia Red - Early 911S Registry #3174
  6. #2726
    Senior Member lopena's Avatar
    Apr 2003
    New Jersey
    I received my restored 1969 door pockets from Tony Garcia (Autobahn Interiors). He did a great job, as expected. Not quick (5 months) or cheap ($450/pair) but I’m v. happy with the final results.
    Alan
    N.J.
    Alan
    N.J.
    1964 E-Type roadster
    1969 911S
    1988 328GTB
    2002 Maranello
  7. #2727
    Sep 2019
    Scituate, MA
    Thought I'd check the AFR today after the car was bucking at low RPMs.
    Turns out it was running a bit lean so richened it up a little and its' much smoother now.
    Found a decent path for the sensor cable from the exhaust tip into the car and up to the passenger seat (where the control unit was).
    Attachment 546278
    Iain
    1970 911E coupe conda green
    2018 911 GTS coupe silver
    Early S Reg #3880
  8. #2728
    Senior Member uai's Avatar
    Jan 2011
    Horb a.N. Germany
    Quote Originally Posted by Ukusto View Post
    I am lucky that I bought a 14point7 idash when they were still available (it's a shame they are not available any longer)
    that makes it easy as you do not need a cable for the display - just connect phone or tablet through wifi to the device
  9. #2729
    Junior Member rangrbob's Avatar
    Mar 2016
    Colorado Front Range
    I had some old knee pads laying around and decided to try and fab up a one piece unit. I used some 22 gauge sheet metal to make a filler piece for the ashtray, and welded it in. My plan is to sand blast and powder coat it, then re-glue the original rubber/foam padding back on and use spray foam to fill in the center. Once the spray foam sets up, I’ll shave it into shape and cover it in the same vinyl I used in the rest of the car.
  10. #2730
    Installed the radio I restored
  1. My COA came today....
  2. Looking at a '72 E today
  3. Today I am a happy man!
  4. Where is this car today?
  5. They came today!!!
