View Poll Results: Does your Karmann-built car have panels w/ 'matching numbers'?
Voters
14. You may not vote on this poll
  • YES - I have a Karmann-built car w/panels w/ 'matching' nos
    7 50.00%
  • NO - I have a Karmann-built car and it does NOT . . . . etc
    1 7.14%
  • YES, BUT . . . My car isn't Karmann-built, but has a numbered panel
    6 42.86%
Multiple Choice Poll.
Results 1 to 10 of 11
Thread: POLL/Cars + Panel Numbers
    POLL/CENSUS: Cars + Panel Numbers
    Came across this a few months back . . . now just getting around to posting a poll . . .
    http://www.early911sregistry.org/for...ocations/page2
    Turns out that long wheel-base Karmann-built bodies have two-digit ID numbers stamped on some parts of them --- at least on the tops of inner door panel stampings, and on the stiffener underneath/inside the rear deck lid --- whether the lid be steel or alu
    These two-digit numbers seem to match-up w/ the 'tunnel' number . . . the one stamped into the edge of the access port for the shift coupler, at the rear of the passenger compartment
    Karmann-built cars have a '2' in the 6th-position of their VIN . . . but this poll is not specific to any type or model . . . just long wheel-base cars built from '69 on. According to the Red Book, Karmann only built coupe bodies --- 'T's + 'E's in '70, then 'T's only after. But --- that doesn't mean a non-Karmann-built car doesn't have this stuff
    (I got started on this whole subject because I installed an alu lid w/ a 2-digit number stamped on it --- on an 'S' car, so . . .)
    Not sure when this practice started --- or stopped . . . but this stuff's turned-up on early '70s cars, so . . .
    Anyway, here's a poll . . .
    Bump . . .
    Atlanta, GA
    My 65/66 has stamped fenders, doors and engine lid.
    Mark Erbesfield
    1973 911S #9113301282
    1957 356A #58648
    1982 Toyota Land Cruiser FJ40
    1977 Toyota Land Cruiser FJ40
    1979 MB 450SL "Dad's old car"
    2019 Cayenne "Wife's car"
    Bump . . . .
    May 2011
    Chelsea, Québec
    Name:  1966 911 (2).jpg
Size:  117.5 KB So my car is not Karmann built and the headlight buckets have the three digit number stamped on them, as does one door. The other door has a two digit number stamped... 90 ... does this indicate that it was taken from a Karmann car at a later date? I have an invoice that shows work was done on the door in the early 1970s... perhaps the door was changed out?
    Member #1616
    Jan 2011
    DFW TX
    The location of the number looks different. Mine is in the same place as Rick's at the very top of the door.
    Numbers on Body Panels
    Porsche seems to have continued the practice of stamping identification numbers on some of the major panels of its cars --- as seen on the 356 . . . up through the SWB 911 cars . . . then stopped --- not sure when
    As for Karmann . . . they seem to have continued stamping numbers up thru production of their 'C' + 'D' program (Aug '69 to Jul '71) cars --- LWB . . . possibly, even later . . .
    . . . hence the poll
    Short Version:
    On a short-wheel-base car, I would not be surprised to see numbers --- 2-digit? . . . stamped on doors, headlight buckets, hoods + engine covers
    But, on a long-wheel-base car, I would be surprised to see any numbers stamped, on any major panels . . .
    . . . unless it was a Karmann-built car --- as identified by VIN
    HtH
    3-digit ID Numbers
    Here's an interesting thread --- a '70 T being by Enrico (Herbie) restored in Italy . . .
    http://www.early911sregistry.org/for...ation-in-Italy
    . . . w/ 3-digit (!) ID numbers stamped on a body-panel
    Not sure if this is a Karmann-built car or not. Either way, more details forthcoming, hopefully . . .
    Karmann Numbers
    . . . more details forthcoming, hopefully . . .
    K-OK --- took me 4 years, but . . .
    Quote Originally Posted by Herbie View Post
    . . . These are the last 3 digits of the production number on the doors, while on the dashboard and on the tunnel (beside the gearbox "hole"), the production number is complete. This car is a Karmann . . .
    My 69 E, Karmann built, has 20 stamped on the engine lid stiffener.
  1. Replies: 28
    Last Post: 07-13-2019, 09:53 AM
  2. POLL/CENSUS: Numbers Matching?
    By LongRanger in forum Technical Info
    Last Post: 01-06-2015, 10:58 AM
  3. Correct leather door panel material for LWB cars?
    By hopper in forum General Info
    Last Post: 08-11-2013, 07:28 AM
  4. POLL/CENSUS: What's Your License Panel? . . .
    Last Post: 08-01-2013, 03:30 PM
  5. POLL/CENSUS: Numbers Stamped on your Engine Lid . . .
    Last Post: 08-01-2013, 03:27 PM
