Results 1 to 10 of 12
Thread: Refurbishing Original Shift Knobs
    Jun 2003
    Bend, Oregon
    Has there been any discussion on whether it's possible to replace the crystal on old shift knobs? Is it an actual lens or a layer of clear plastic molded into the body of the knob? I'm about ready to experiment with one.
    JohnA
    Jun 2012
    London, Ontario, Canada
    I have pecked away at one. The crystal appears to be glued in. It is also harder than the surrounding black material, so if you try to lever it out, you damage the surround. Maybe you will have better luck...
    Ravi
    Early 911S Registry # 2395
    Nov 2002
    Worshington State
    You may want to do a search on the bird (Pelican). There was a guy doing returns there. Don't believe the results were as good as factory but a definite improvement at a reasonable price compared to buying a reproduction.
    ...just a wild guess, but could you use/modify a windshield repair kit to fill and finish?
    Bill
    Bill
    1969 911T - sold
    2001 911 Turbo - sold
    1996 911 C4S - returned
    1982 911SC - gone
    1960 356 Roadster - sold
    Feb 2011
    Spain
    I think it is really hard plastic. Polishing migth work.
    I think the black part is Bakelight and the clear par is plastic or clear resin of some type. Interesting to see how they manufacture this piece.
    Jun 2003
    Bend, Oregon
    The main thing I'm wondering is how the lens is constructed - if it's a thin lens that can be removed, or if it's as you say some type of resin pour. Seems like the lens could be cut away with a Dremel or somesuch and replaced. If it's resin it might be impossible to remove it. I hate sacrificing an original to experiment, but I'm about ready to try.
    JohnA
    Jul 2011
    Chicago Area
    John you can't remove the clear plastic insert without damaging the silver outline and shift pattern. I have a system I use to restore the knob as long as the shift pattern is OK and the real problem is the cracking and crazing of the clear insert. Post a picture of your knob and I will tell you if I can restore it for you.
    Mike Fitton # 2071
    2018 911S Carrera White
    Jul 2011
    Chicago Area
    Here is a before and after picture of a knob I just restored:
Size:  103.7 KBName:  IMG_0442.jpg
    Mike Fitton # 2071
    Jan 2007
    North of the GG Bridge
    It is a matter of buffing the crazing out of the clear cap. As an experiment I have done this by hand as I was a bit timid of jumping in with a buffing wheel/compound. By hand was time consuming but it did allow me to see the gradual effects. With any polishing project I imagine that starting with a lighter buffing compound and testing is the way to go. Be careful to not distort the shape of the clear cap with a power machine.
  1. Original vs. Repro 901 Shift Knobs
    By jaudette3 in forum Technical Info
    Last Post: 02-10-2016, 11:25 AM
  2. FS: Original 901 Shift Knobs
    By jaudette3 in forum For Sale: 911 Parts
    Last Post: 05-02-2013, 01:37 PM
  3. FS - Badge, 901 Shift Knobs, Short Shift, Dash Switches and more
    By tgittens in forum For Sale: 911 Parts
    Last Post: 02-23-2010, 07:38 AM
  4. FS: 901 shift knobs
    Last Post: 07-16-2008, 07:11 AM
  5. 5 spd OE 901 Shift Knobs
    Last Post: 07-23-2006, 04:50 PM
