Results 1 to 10 of 13
Thread: Does anyone have picture(s) of window/fixed vent window area
    Apr 2011
    N.Calif., south of SF
    I am replacing the L&R rubber window scrapers and the small black molding that sits below the fixed vent wing window. I am trying to determine if this small sealing piece butts directly against the rubber window scraper? .... or is there a small gap? Also does this piece run all the way to the leading edge to the window frame?
    Hope this makes sense?
    Haasman
    Haasman
    Registry #2489
    R Gruppe #722
    65 911 #302580
    70 914-6 #9140431874
    73 911s #9113300709
    Apr 2011
    Anybody?
    Haasman
    Haasman
    Registry #2489
    R Gruppe #722
    65 911 #302580
    73 911s #9113300709
    Oct 2012
    Minneapolis
    I'll go take a couple. I even have one side with the trim off.
    -Kris Clewell
    Professional photojournalist
    red decklid club member #1
    Oct 2012
    Minneapolis
    alright what you said kind of makes sense. I am assuming that you are noticing the gap in the window scraper? one side of my car has more gap than the other. I do think these seals did shrink. I've seen the vw golf stuff from 70's/80's also in OE form having different size gaps. I think they shrink. Originally I dont know how much or if there was any gap, however I doubt it as the fit/finish wouldn't be desirable. someone should measure a new one?
    there is about a 3/8ths gap on the right side of this one by the edge of the door frame. its snug on the window. it will slide back and forth.
    the other side has much less gap.
    -Kris Clewell
    Apr 2011
    Thanks Digital K-
    To be clear, this is the small black piece I am speaking about-
    Name:  Window trim .jpg
    Haasman
    Haasman
    Registry #2489
    R Gruppe #722
    65 911 #302580
    73 911s #9113300709
    Oct 2012
    Minneapolis
    oh gotcha. need more photos or does the one work for you? I still imagine these shrunk as well, and bet they went all the way to the window scraper when new.
    -Kris Clewell
    Apr 2011
    That's what I am wondering. I can put a little cement in the "grove" to hold in place after warming them a bit to stretch?
    This is one of those details I have looked at hundreds of times but never noticed exactly where they run from the leading edge of the door back towards the window scraper.
    Haasman
    Haasman
    Registry #2489
    R Gruppe #722
    65 911 #302580
    73 911s #9113300709
    Oct 2012
    Minneapolis
    Quote Originally Posted by Haasman View Post
    Haasman
    Im not sure warming them up and stretching them out is going to make you happy. I bet new seals for this spot are pretty reasonable. I've admittedly never looked so who knows. Anytime I take this stuff apart and im redoing a car thats this old I just try to replace all the rubber. I've done it a couple times on old watercooled vw's and it makes such a huge difference in noise, and quality of ride. The old seals just shrink, or harden and get dried out, they are just junk. The only problem is non OE stuff (at least for vw) thats remade never fits right, and its a cluster getting all the glass in to fit just right.
    -Kris Clewell
    Apr 2011
    Digital K- I agree totally, that is why I am using new seals. I found if I warmed them slightly they expanded to provide good length.
    Its the exact placement/location that I am after.
    The old ones were hard and brittle. New ones are heap. Well worth to help keep moisture out of the doors.
    Haasman
    Haasman
    Registry #2489
    R Gruppe #722
    65 911 #302580
    73 911s #9113300709
    Oct 2012
    Minneapolis
    Haasman
    oh good luck! I thought you were going to stretch out decades year old seals haha
    -Kris Clewell
  1. Advice on Soft Window Targa vs Fixed window
    By Max (SD) in forum General Info
    Last Post: 08-04-2013, 03:22 PM
  2. Soft Window Targa to Fixed Window
    Last Post: 03-04-2013, 02:11 PM
  3. WTB: PS (right) fixed vent window for 73
    By merbesfield in forum For Sale: 911 Parts
    Last Post: 02-13-2013, 02:22 PM
  4. drivers side vent window trim (black) fixed window and og glass $100
    By scuppernongwine in forum For Sale: 911 Parts
    Last Post: 05-30-2012, 07:14 AM
  5. Replies: 4
    Last Post: 10-09-2011, 02:09 PM
