Thread: Steering wheels
    Steering wheels
    Is there a difference between a RS steering wheel of 380 mm and a 914 or 914/6 wheel of 380 mm?
    Is part number 914 347 804 20 a 3800 mm?, which was what the rs used, but they gave it a 914 part number?
    Thanks for the help..
    RGruppe member 445
    Jan 2003
    NW Indiana
    Well Andy B is asleep by now so when he is up tomorrow I know he can give you all the correct part #s, but the most common wheel I have seen in the RS is 914 ending with 806.10
    Yes all the Carreras came with a leather 380 mm 914 wheel. The RSR came with one also but it was modified to a larger circumference rim.
    Brian
    '71T
    R Gruppe #299
    Jan 2003
    UK
    John - I've never seen an '804.20' wheel ... are you sure it's not 804.10 ? That would be a 380mm hard palstic 914/4 wheel.
    Any pictures you can post ?
    Andy
    Early 911S Reg #753
    R Gruppe #105
    It is an 804.10 wheel. Thanks for the help on this. Since there are several part numbers and other qualities, this can get a bit confusing.
    RGruppe member 445
    I just purschased a nicely re-done 804.10 wheel for my 1970 S. If this were for an rs, I think I wiuld have searched out the wheel it came with.I think this should work out nicely!
    RGruppe member 445
  1. steering wheels
    By typ901 in forum For Sale: 911 Parts
    Last Post: 06-23-2011, 09:47 AM
  2. 911/356 steering wheels
    By 911s55 in forum Technical Info
    Last Post: 04-14-2008, 09:26 PM
  3. FS: Steering wheels
    By 70SATMan in forum For Sale: 911 Parts
    Last Post: 10-24-2006, 05:05 PM
  4. oe steering wheels
    By joelrkaplan in forum Technical Info
    Last Post: 03-17-2004, 05:27 PM
  5. Steering wheels
    By thback in forum Technical Info
    Last Post: 06-12-2001, 02:24 PM
