Page 1 of 6 123 ... LastLast
Results 1 to 10 of 55
Thread: 1965 Gas tank colors and textures?
    Hello,
    I'm new to posting on the forum. I have searched for this information but I haven't really narrowed down my plan. I'm restoring a 65' to a high level with hopefully the correct details.
    This tank had undercoating sprayed all over it but I found the correct gray color when I scraped it off. My questions are
    1. The entire tank was sprayed gray at the factory?
    2. The thick dynamat looking stuff was applied over the gray paint in the area of the spare tire bump and left black?
    3. The bottom was left gray or sprayed black textured with the rest of the body?
    The tank has been dipped and lined inside. I have the exterior sprayed with grey epoxy primer that matches the gray that I found on the original tank. Just need to decide to leave the bottom gray? And spray bedliner the tire bump area to somewhat copy the thick sticky mat.
    Thanks for any help.
    Sep 2006
    La Quinta
    Brad, my '65 tank is gray top and bottom with no texture. Hope this helps.
    1965 911 #301111, Red Book Vol 1 "Cover Car," owned 53 years.
    1967 911 #307347, bare-bones, some road wear, a little surface rust, and a few dents..., owned 13 years.
    Registry #983
    R Gruppe #741
    Hi Brad, My '65 (301994) tank was all gray and then had body underseal applied to the bottom. I used the POR15 system and paint followed by Wurth Underseal. The last picture showing the "dynamat looking stuff" was taken from Darryl's restoration site for his '65 912.
    Aug 2009
    SF Bay Area
    Original, unrestored, unmolested tank in Ch # 303366
    Senior Member E911's Avatar
    Dec 2011
    Frozen Tundra
    Brad- I think you will find different answers depending on build date... my unrestored '65 is smooth grey with undercoating on the bottom and the "tar" like substance where the spare goes (like 19-911-65's restored pic above).
    Sep 2006
    La Quinta
    Yep, it seems to be moving as the build date changes.
    Registry #983
    R Gruppe #741
    This tank was smooth gray with some spraybomb black coating on it when I scraped it down. I'm confident the smooth gray was all over the tank orginally. The dynmat stuff was applied after the paint. At least there was gray under it.
    So technically I can spray the bottom the same texture/black coating as I put on the undercarriage? The grey from the bottom looks a little goofy to me.
    When I ordered parts the other day they told me it was an early 65' by the serial #.
    Thanks for all the help.
    Aug 2009
    SF Bay Area
    Brad
    What is the serial #? That should help to establish a trend.
    Jim
    OK, the serial # is 301497
    Does anyone know where I can get a tank drain? I seem to have misplaced this one.
  1. Original gas tank colors + luggage comp.
    By vricardo in forum Technical Info
    Last Post: 06-03-2018, 08:17 AM
  2. WTB: oil tank for 1965 911
    By ErichW in forum For Sale: 911 Parts
    Last Post: 10-31-2013, 05:47 PM
  3. 1965-1973 gas tank support
    By Mike Dejonge in forum For Sale: 911 Parts
    Last Post: 11-27-2012, 04:18 PM
  4. Replies: 7
    Last Post: 11-15-2010, 12:08 PM
  5. 1965 Porsche 911: Gas Tank
    By Dave McCay in forum General Info
    Last Post: 03-23-2006, 12:38 PM
