Page 2 of 2 FirstFirst 12
Results 11 to 18 of 18
Thread: 72 S Engine Sound pad
  1. #11
    Feb 2010
    San Francisco, CA
    Good to hear. I should be receiving my pad from Bob tomorrow. I expect that it'll be a nice fit.
    E911SR & RGRUPPE
    '73 S Coupe #306
  2. #12
    Apr 2011
    N.Calif., south of SF
    I think you will be pleased. It takes a little bit of working to get it into a good position, especially the left front side (beyond the fuel filter). I didn't rush to get it under the top metal tabs since they have a limited bending life, saving them for last. I also removed the air cleaner for ease of access.
    Haasman
    Registry #2489
    R Gruppe #722
    65 911 #302580
    70 914-6 #9140431874
    73 911s #9113300709
  3. #13
    Quote Originally Posted by Haasman View Post
    Replaced my pad with the Appbiz one also. Works well and Bob was right, you don't have to glue it in. I like that since in certain situations glue can trap moisture. With the Appbiz pad it is held in place by the body clips above and simply tension of being folded.
    Bob also suggested using velcro in strategic locations to hold it in place but that didn't work for me. The velcro didn't want to stick to the original dried glue and within one day started to sag over the air cleaners. I eventually glued it down with some 3M adhesive spray and its working great.
    Kent: Can you post a picture of the 3M can?
  4. #14
    anyone try the magnet mounting? I'll never glue another pad in, too much mess.
  5. #15
    Quote Originally Posted by kentf14 View Post
    Here you go Edric. Nothing like setting your timing by the dark of night. Really makes the timing gun work well
    Nice period-correct/number sequence-correct California blue plates!
    Peter Kane
    '72 911S Targa
  6. #16
    Apr 2011
    For me with the 73 the interference fit after the folding made it stay quite well. I didn't use any adhesive or attachment method. I did a final location check, and then made sure it was correctly placed in relation to the upper tabs.
    Haasman
    Registry #2489
    R Gruppe #722
    65 911 #302580
    73 911s #9113300709
  7. #17
    Hehe - go Giants
  8. #18
    Feb 2010
    San Francisco, CA
    Got the pad installed in a snap. Only needed adhesive in the upper corners. Excuse the lumpy appearance, I've got a few anchor bolts for harnesses under the pad.
    E911SR & RGRUPPE
    '73 S Coupe #306
  1. Engine Sound Pad
    By edmayo in forum Technical Info
    Last Post: 06-05-2022, 11:43 AM
  2. WTB: Engine Sound Pad
    By Larryg57 in forum For Sale: 911 Parts
    Last Post: 09-23-2011, 08:58 AM
  3. WTB - Engine Sound Pad for 911 SWB
    By IAA1963 in forum For Sale: 911 Parts
    Last Post: 08-24-2011, 10:47 AM
  4. WTB: Engine sound pad for swb/'67
    By buddeman in forum For Sale: 911 Parts
    Last Post: 07-31-2010, 09:32 PM
  5. Engine Sound Pad
    Last Post: 01-18-2006, 02:00 PM
