Thread: Help identifying Fuchs?
    Mar 2013
    Surrey, UK
    Hi,
    I've been trying to work out if my 'Fuchs' wheels are genuine or not and have concluded that they are probably copies. They look genuine to me but no not have any manufacturers marks on at all. All the postings related to genuine Fuchs that I've seen have the part number on the back of the spokes with the Fuchs logo. However, they do have a date stamp, which looks like 6 70 and the number 4 above it. Any ideas what the wheels are? They measure 7 (from the interior of the rim) by 15.
    the reason that I took the wheel off is that I am missing a spare. I put the 7x15 in the spare wheel well to try it for size, but this is clearly wider than the original as the carpet doesn't lie flat. The car is a 1970 911 T. What should the size of the original spare be?
    Please excuse the dumb questions - I've only had the car 1 month.
    Many thanks
    Paul
    Name:  Fuchs interior 2.jpg
Size:  92.2 KBName:  Fuchs interior.jpg
Size:  72.8 KBName:  Fuchs Wheel.jpg
    Looks original and worth more than what the car should have. Your car should have 6 x 15 Fuchs, commonly know as deep 6s. That wheel there if 7x15 is what is known as a 7R. The 7Rs used (mostly) an ink stamp hence no raised numbers, but one of the rear of the petals will have grind marks which was done to remove the deep 6 number. If you need a correct wheel we could sort a deal?
    HTH
    Alan
    Jul 2003
    Santa Cruz, CA
    Looks like a 7R wheel to me as well...
    Those go for about 1.2k to 1.5k per wheel in that condition.
    Michael
    -Dusty 70S Coupe
    -S Registry #586
    Mar 2013
    Surrey, UK
    Many thanks Alan, that's a relief. I checked the rears too, which are clearly the real deal. Here's a picture of the car with them on.
    So, I just need a single deep 6 for the spare.... If you have one then please let me know.
Size:  62.6 KBName:  Fuchs Rear interior 2.jpg
Size:  89.5 KBName:  Fuchs Rear interior.jpg
    Name:  Fuchs Rear Wheel.jpg
    I am sure I will have one, we have a few spare.
    Are you looking to p/x with the 7R? If so you will be in credit, thus anything else you need for your car?
    Alan
    Mar 2013
    Surrey, UK
    Thanks Alan, I just need one for the spare. I'm not planning to part with the current set I have. I'll give you a call on Monday.
    Paul
  1. Help Identifying Tranny
    By D.Ehinger in forum General Info
    Last Post: 01-01-2014, 07:40 PM
  2. Need help identifying these cars.
    By LKreg in forum Other Car Cultures
    Last Post: 08-29-2011, 11:59 AM
  3. Need help identifying and pricing
    By speedo in forum General Info
    Last Post: 07-08-2008, 05:14 AM
  4. Help on identifying a car
    By goldsc78258 in forum Technical Info
    Last Post: 01-23-2008, 04:07 PM
  5. help identifying oil coolers
    By typ901 in forum Technical Info
    Last Post: 06-12-2004, 01:56 PM
