Thread: Hydro Pneumatic strut replacement
    '69 T originally equipped with comfort group, hydro pneumatic (H-P) struts. In addition to the strut, the a-arm and a-arm support/cross member are H-P specific.
    A source says that 3.2 Carrera front suspension (strut, a-arm, cross member, torsion bar, steering rack, and sway bar) will retro-fit to a 1969 chassis. According to the source, this is a common update for H-P equipped cars.
    Any comment or experience with this solution?
    Aug 2009
    SF Bay Area
    Quote Originally Posted by dchunk911 View Post
    You need to check your control arms and cross member. 69s mostly came with control arms that have splines in them (the same as regular 911s and 912s) They didn't put hollow a arms on H-P equipped cars until the 70 YM cars. All you should need to do is add torsion bars and adjusters along with a couple of regular struts from any car from 69 on. It becomes just a matter of choice (and pocket book) as to what strut/brake combo you want to use.
    Jim
    Jim,
    Thank you for your input. I checked, and this '69 does have splines in them.
    I really appreciate it!
    Feb 2005
    Lake Tapps, WA
    I have a set of hydro pneumatic struts that were recently rebuild with new Bilsteins inserts. They have 3.5" bolt spacing. If interested let me know...probably easier and cheaper to just swap mine for yours
    '67 911S
    '69 911S
    '70 911ST
    '73 911T Targa Signal Yellow
    '11 Spyder
    Early S#1097, R-gruppe #
    I did not know that the hydros could be fitted with Bilstein inserts. Obviously, they were re-machined?
    How much do you want for them, and I assume you need the cores?
    Feb 2005
    Lake Tapps, WA
    My mistake, they are Koni inserts. $250 + shipping. I don't need yours in exchange.
    '67 911S
    '69 911S
    '70 911ST
    '11 Spyder
  1. FS: Front and Rear Hydro Pneumatic Struts removed from my 69T
    By leedurrant73 in forum For Sale: 911 Parts
    Last Post: 07-21-2013, 02:39 PM
  2. Hydro Pneumatic suspension
    Last Post: 07-21-2013, 07:26 AM
  3. Front strut replacement
    By ferry58 in forum Technical Info
    Last Post: 12-22-2011, 08:32 AM
  4. Bilstein strut insert replacement
    By NickP in forum Technical Info
    Last Post: 08-04-2009, 12:04 PM
  5. Hydra-pneumatic front struts have failed
    By W Scott Shores in forum General Info
    Last Post: 06-10-2004, 08:38 PM
